Old 12-31-2009, 02:08 PM
corbinace corbinace is offline
Default Wheel pant upper clearance
Good morning,
The common practice calls for one inch of clearance above the tire for the wheel pant. Can this be safely reduced? If so, what is the least amount of space/clearance one should allow? What is the most amount that the tire could grow. Snow is not really a concern for me, as I have only flown off of it maybe three times in 13 years. What else am I missing?
I am fitting the large wheel pants around my current 6x600 (17" dia) tires until they wear out when I will install already purchased 6X15 (15" dia) tires. The reason for not just fitting them to the smaller tires now is that, I may not like the 6X15s and may want to go back to the 6X600s later.
Thanks for the insight, Tim.
Old 12-31-2009, 06:11 PM
Bavafa Bavafa is offline
If the new tire (same size) is more square then the existing one, it could get too close to the edges. With one inch clearnce you are rather safe with a square type tire as well.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 12-31-2009, 07:01 PM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Default bottom clearance, too
I just discovered that a hard landing can damage the bottom of the main wheel fairings. Mine are mounted with very little clearance to top of tire. I have to use short screws at the peak of the tire to join front and read halves of the pants. Just a thought for you.
H. Evan's RV-7A N17HH 240+ hours
We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" net of PayPal cost for 2015, 2016, 2017 and 2018 (December).
This airplane is for sale: see website. my website
