Tip: Slick Magneto Alignment
When stabbing a slick mag do not use the steel alignment tool supplied by Slick mag. If a friend, helper, or even yourself moves the prop before the alignment pin is removed and after stabbing, the disk block & gear assy. will be ruined. (257.95) from Spruce) Use one of the soft pop rivet made to fasten the canopies.
Happy New Year To All
G.P.
