Old 01-18-2006, 10:48 AM
FlyQXCRJ FlyQXCRJ is offline
Default How do you heat your shop?
I have about a 550 square foot shop that is detached from my house - that means I have no heat. It being winter in Oregon - I'M COLD!
Does anyone have any suggestions on how to efficiently (cheaply) heat that kind of workspace?
Matt
Old 01-18-2006, 10:56 AM
RV7Factory's Avatar
RV7Factory RV7Factory is offline
Chief Obfuscation Officer
Matt, see this thread.
I ended up purchasing a small 1500W electric heater with a fan built in from HD. It takes the chill out, but on the coldest nights I still need a sweatshirt. For your shop, you probably want something with a little more power.
On a related note, find an old piece of carpet or similar to keep you feet somewhat insulated from the cold concrete (assuming that's what you have), you might be amazed at what a difference it can make. Your body can loose a lot of heat through your shoes/feet.
Brad Oliver
Livermore, CA | RV-7 | SOLD
RV-7: RV7Factory.com | iPhone app list: AviatorApps.com | Photography: BradOliver.com
Old 01-18-2006, 10:59 AM
thallock thallock is offline
Matt,
I solved that problem by moving my shop to Texas. It was 85 deg F last week. I use a small electric heater when it gets really cold (all the way down to 45 last Saturday morning). Does that help?
Tracy.
Old 01-18-2006, 11:01 AM
Originally Posted by thallock
Matt,
Tracy.
Thanks, Tracy - I've already had the pleasure of living in Texas. If it stopped raining here for just a few minutes, I might stop missing it!
Matt
Old 01-18-2006, 11:07 AM
ericwolf ericwolf is offline
Default Modine Hot Dawg
I have a 20' X 20' detached garage and heat it with a 45,000 BTU Modine Hot Dawg garage heater on a thermostat. It runs on natural gas (or propane if you like) and vents to the outside. Since I work for Modine, I get a significant discount. I usually keep it at 40F unless I?m in there, then I heat it to about 55F.
Regardless of the heater, I think that it is important to insulate the workshop and attempt to seal the leaks around doors & windows.
Eric Wolf
RV-8A Flying since May 2009, 300+ hours
Mattituck IOF-360, WW 200RV Prop
N184EW
Past President, EAA838 Racine, WI
Old 01-18-2006, 11:11 AM
Matt,
I spent 4 years in Vancouver, Wa, and loved it there. You can't beat the country. We got the same amount of rain as Austin, about 30-35 inches. The difference was that Vancouver spread it out amoung 330 days, whereas Austin does it in about 20 days.
Sorry for making you homesick. At least you can drive over to Van's when you need a part.
Tracy.
Old 01-18-2006, 11:21 AM
Kenneth's Avatar
Kenneth Kenneth is offline
Matt,
I'm in the process of installing a Sterling SF045 45,000BTU natural gas heater for my 3 car garage.
My original thought was to install an electric heater that hung from the ceiling since I ran a 60amp subpanel to my garage while getting it ready for the build. However, I calculated that it would cost approximately $.80/hr to run a 15,000BTU unit. Even a best case scenerio that it ran only a few hours per day, the cost would very quickly add up. (I plan on keeping the garage at a steady 50F throughout the winter. I hate cold tools.)
Eventually I found a gas fired unit that draws it's combustion air from the outside for around $900 including shipping. The 45,000 BTU unit will burn gas at a rate of about $.30/hr. Still not cheap, but I figured over the course of the entire build process the choice to go with gas vs. electric would more than pay for itself. (Especially since the output is more than twice with the gas unit, thus reducing the amount of time it runs.)
If you want more information, check out this site: Click Here
I eventually bought my unit from these guys and am very satisfied with them: H-Mac Systems
I'll hopefully have the gas and electric finally completed tonight and will let you know how it work.
--Ken
Ken Monville
http://www.bandwidth.org
RV-8 - Wings, sold
RV-8 - 2nd project in planning
Old 01-18-2006, 11:37 AM
Louavul's Avatar
Louavul Louavul is offline
Default Garage Door Insulation
When we lived in the best kept secert of New Mexico we had a two car garage (shop) that had this .0 too thin metal two car sized door that just sucked the heat out of the area like a sponge. We found some 4 x 8 sheets of rigid panel type of insulation which we cut and glued into the segments of the door. That along with a new weather strip at the bottom of the door and one of those oil filled heaters from Target made the place quite comfortable all winter long.
Now, in Texas its ice tea and a fan all year long.
Steven L. Hild
La Vernia, Texas
RV-7, Fuse
Old 01-18-2006, 11:44 AM
rv8bldr's Avatar
rv8bldr rv8bldr is offline
I used a mini-flame thrower from Coleman. It runs off a propane tank.
Cheers
Mark
RV-8 C-GURV (Flying since Nov 2004) - Sold
Scratch building 4pl Bearhawk
Flying a '79 Maule M5-235C
President EAA Chapter 245
Old 01-18-2006, 12:19 PM
mlw450802's Avatar
mlw450802 mlw450802 is offline
I use one of these:
http://www.comfortglow.com/blueflame/cb20t.html
It's been in the garage for 3 years now and really warms up quickly.
It's a wee bit fumey during certain times of the year (change in Natural gas origin?) but generally it's not noticeable.
I'm in Columbus, OH and our winters are fairly mild but the heater is up to the task even in below zero weather.
-mike
Michael L Wilson
Resuming building after a 4ish year hiatus! (life got in the way)
N194MW (reserved) RV9A SB
VAF# 148
Payson, AZ
