Old 12-26-2009, 07:39 AM
Chappyd Chappyd is offline
Default Camloc for oil door
I'm using the stock Van's cowl and oil door. It came out really well, but I want to replace the "elephant ear" stock camloc devices with a flat or phillips head unit. I looked at Aircraft Spruce's web site to look them up, and am unable to identify which ones I should get. I can't find any useful markings on Van's camloc.
Which ones should I get??
Dave Chapdelaine
N821RV
RV-7
Flying as of 7/2/11
Old 12-26-2009, 07:49 AM
DarylT's Avatar
DarylT DarylT is offline
Default Milspec
Dave - not sure how much room you have on the back but Milspec is what I used on the cowl instead of hinges.
http://www.milspecproducts.com/
They have different styles and probably have one that would work.
Daryl Tolliver
VAF 1086
Yes: I paid my =VAF= membership dues for 2020
RV-7A - N754RV: Status - Pink Slip is In! First Flight 8/23/12 - My First Flight 9/24/12!
Home from GloCustom for Paint! 3/16/13
957 hours and climbing
7th Condition Inspection complete 10/31/2019
Superior XP IO360 (180 HP), Hartzell Blended Airfoil, AF-5400 EFIS panel, Garmin Aera 660, TruTrak Vizion 385 AutoPilot, Dual Pmags
Houston, TX
Track: SPOT
Weiser Airpark (EYQ)
http://www.rv7a-factory.com
Old 12-26-2009, 08:24 PM
tomagin tomagin is offline
Another source is Skybolt
www.skybolt.com
I bought the kit for attaching the cowling and had two camlocks leftover which I used on the oil door. Installed the invisible hinge and a metal strip at the bottom to support the camlock recepticals. Much more secure, flush with the cowling and matches the other fasteners.
Tom Agin
Port Orange, FL
QB RV-8 completed!!
XIO-360-M1B with LASAR
GNS-430, GI-106A, GTX-330, 9000EX, Becker 4201, Digiflight II VSGV, ADI, Dynon Dlight Dek 180, Vertical Power VP-200
Old 12-26-2009, 10:03 PM
dhall_polo's Avatar
dhall_polo dhall_polo is offline
Default ditto Tom
Those two leftover skybolt camlocs went towards my oil door as well, along with my homemade hidden hinge.
some pics from my construction site...
Don Hall
N517DG - RV7 - Flying!
Ticked Van's Hobbes meter at #6110, 3/7/09
