Old 12-21-2009, 07:50 PM
vbpiper's Avatar
vbpiper vbpiper is offline
Default Attach air seal fabric with screws?
Has anyone attached the air seal fabric to the baffles with screws and large-area washers? I am about to attach the fabric and am considering using washer-head AN525 screws or regular screws and large-area washers rather than the supplied rivets. I guess the real question is: how long can I expect the fabric to last? If I need to replace it every few years, I think I will use the screws. If it lasts a long time, I will use the rivets and not worry about it.
Any thoughts are much appreciated.
Thanks.
RV-7A Finish kit
Renewed 8-14
Old 12-21-2009, 08:34 PM
kevinh's Avatar
kevinh kevinh is offline
About 4 yrs for me and the rubber baffle material is still fine. Even if I had to replace it, I'd still prefer pop rivets because they are super fast to drill out.
-kevinh, Track my RV-7A, flying, alas, sold in 2013 after 450ish hours. (I'm now building something different)
Old 12-21-2009, 08:45 PM
Rockyjs Rockyjs is offline
I considered using screws also, but in the end went with rivets. They are simple and I agree with Kevinh easy to drill out if necessary. The material will last a long time.
Rocky McKiernan
Navarre, FL
N767JM RV-7 Flying
N1011D (res) RV-10 Building
Old 12-21-2009, 08:58 PM
N941WR's Avatar
N941WR N941WR is offline
Screws and engine vibration may not work out, long term. YMMV.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 12-21-2009, 08:59 PM
Jim P's Avatar
Jim P Jim P is offline
For what it's worth, I used #6 Tinnerman washers and AN470A-4 soft universal head rivets and it seemed to work out well. I know a universal rivet isn't designed to fit a tinnerman, but being a soft rivet, it gives enough surface area with the washer, but doesn't crush the baffle seal too much when squeezed. I figured that I'd have to drill them out at soem time in the future so I wanted to make it easy on myself.
http://adap.com/rv7/IMG_0612.jpg
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
Old 12-21-2009, 09:03 PM
vbpiper's Avatar
Talking Thanks for the answers!
Looks like rivets it is. Thanks for the quick responses!
RV-7A Finish kit
Renewed 8-14
