Originally Posted by rv9aviator
I plan on using switches on my Tosten grip to operate the flaps and trim. Should I also put switches on the panel to do the same in case the passenger is also a pilot? I don't plan on having dual Tosten grips.
As for your trim I would say that is a completely personal decision. One thing to consider though is if you do install trim switches on the passenger side you will have to also install relays. I have the Ray Allen grips and at least for those you do not need trim relays if you are using only one grip.
As for the flaps...well....you're going to need a relay to operate them through the stick anyway so why not put another switch on the panel?
