Old 12-20-2009, 06:50 AM
apkp777's Avatar
apkp777 apkp777 is offline
Default Engine Primer Installation? Where did you put it?
Hey all,
I ordered the engine primer kit from Van's. Just curious where you installed it.
I was thinking right next to the gascolator. However, I am not sure if there will be interference with other installations.
Anyone have a picture they can point me to?
Thanks!
Tony Phillips
N524AP, RV 9 (tail wheel)
Old 12-20-2009, 07:29 AM
Brantel's Avatar
Brantel Brantel is offline
Here is what I did. I bought a heavy duty hex nipple from McMaster Carr.
This does require removing the gascolator to remove the solenoid but I do not expect to ever have to do that.
The engine would fall off before that nipple would break, it is heavy duty!!!!
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 12-20-2009, 08:00 AM
129TG 129TG is offline
Hey Tony;
I am building a 7A and I put mine on the starboard side to the left side of my gascolator and along the side of the firewall. I built an appropriate mount from some scrap angle. The primer tubing T's at the low middle of the accessory case and I then used the motor mount to stand off the connecting tubing to the primer. I have finished the FWF and it did not interfere with any other installation.
Thom Grant
KDTS - Destin, FL
Old 12-20-2009, 08:18 AM
apkp777's Avatar
Cool! Both look like great solutions. I had in mind to do something like 129TG's. I have the Van's gascolator like Brantel's. Brantel's installation is definitely simple. I like simple. I hadn't thought of just attaching it direct to the gascolator. The fitting has to be strong, looks like the one you used is. Do you have the part number for that fitting by chance?
Tony Phillips
Old 12-20-2009, 08:49 AM
Brantel's Avatar
I think it was a McMaster Carr # 48805K81 but doublecheck to ensure it fits your needs.
It is a close hex nipple, stainless, heavy duty.
Old 12-20-2009, 10:59 AM
agough277 agough277 is offline
I mounted mine with a pipe to pipe thread fitting directly to the port on top of the collator
RV6A, RV7, RV6 Wing
Living with my 6A at 3L2 near Las Vegas
Old 12-20-2009, 12:49 PM
jsharkey's Avatar
jsharkey jsharkey is offline
Default On Firewall next to Gascollator
I used Loctite on the screws holding the solenoid to the bracket and I lock wired around the pipe fittings and through holes drilled in the mounting bracket. I also put a "flex coil" in the pipe between the engine and the engine mount fixing points to allow for engine movement on the AV mounts.
Jim Sharkey
RV-6 Phase 1
Old 03-12-2012, 03:10 PM
jbDC9 jbDC9 is offline
Primer solenoids? That reminds me... I have a brand new one in the box, never used. I intended to install a primer system but decided against it. Looks like ACS has 'em at $51.75; anyone want mine for 40 bucks? I'll cover shipping.
John Bixby
RV-8 QB sn 82030 - 1750 hrs
O-360-A1D/CS/Pmags
Houston, TX
Old 03-12-2012, 03:18 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Originally Posted by Brantel View Post
Need some quick help. I'm at work trying to order and don't have the numbers handy. In order to do what Brantel did, I would need (I believe) a 1/4 NPT x 1/4 NPT hex fitting. However, if I chose to use the upper port on the gascolator to connect to the primer solenoid directly, rather than the larger side port, I'm thinking I'll need to order a 1/8 NPT x 1/8 NPT hex fitting. Is that correct? (I'm trying to avoid using copper line on that always-pressurized segment b/w the gascolator and solenoid.) Thanks.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
