12-20-2009, 05:45 AM
Floating anchor nuts?
What are "floating" anchor nuts (F2000-xx). These are the only type spruce has for #4 screws.
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
12-20-2009, 05:59 AM
floating nut plate
the center 'nut' is captured in the plate so that it can move around a bit allowing for less than perfect alignment of the holes to get the screw going.
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
12-20-2009, 06:11 AM
Unlike a nut plate where the threads are cut from the plate itself, with a floating nut plate the self-aligning "nut" is captured in a cage to allow some movement. This allows for attachment of structures despite relative misallignment one with another. They also cost more.
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2021 Donor
12-20-2009, 06:48 AM
Thanks guys!
Phil
RV9A (SB)
Ottawa, Canada
12-20-2009, 09:15 AM
Spruce has regular #4 nutplates. Not sure why they don't list the thread.
MK1000-04
Chanler Childs
RV-8A
Empennage complete
Building wings
12-20-2009, 09:26 AM
i actually need the 1-lug variety... only the floating ones seem to be listed for #4.
Phil
RV9A (SB)
Ottawa, Canada
12-20-2009, 11:41 AM
Phil
Just get the standard MS21047-L04 (two lug) and cut one end off.
The threads will be 4-40.
The L06 is 6-32
The L08 is 8-32
The L3 is 10-32
The L4 is 1/4-28
12-20-2009, 11:53 AM
GAHCO or Bonaero will have all of the varieties (one lug, small lugs, corner lugs, etc.) of floating nutplates you require. They are more expensive, but are pretty nice to work with.
David Maib
RV-10 N380DM
New Smyrna Beach, FL
VAF Paid 1/21/2020
"In '69 I was 21, and I called the road my own"
Jackson Browne
