Old 12-19-2009, 07:37 PM
Flying Scotsman Flying Scotsman is offline
Default Engine turned instrument panel?
Anyone ever try (or have done) an engine turned instrument panel? Someone suggested I look into it for the 7A, as I'm trying for a polished aluminum exterior w/ accent colors on the fiberglass parts.
Just curious as to whether it's been done and if so, how'd it look? Any drawbacks (glare, etc.)?
Sure looks pretty on old cars and boats...
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
Old 12-19-2009, 07:50 PM
rvator51's Avatar
rvator51 rvator51 is offline
Sure looks nice but I am wondering about reflection from it?
Regards,
Thomas Velvick
Goodyear, AZ (KGYR)
2020 Donation sent.
N53KT RV-6a finished 2018, Flying
N7053L RV-4 Wife's RV
N56KT RV-4 Finishing
Old 12-19-2009, 10:39 PM
SMO's Avatar
SMO SMO is offline
Default Have one....
in my RV-4. No problems with reflection. The -4 was built in 1987 and I bought it a couple years ago. The panel still looked pretty good but a bit dull. I redid the panel and in the process reworked the turning - I just used a small wire wheel (from a dremel) in my drill press to get the pattern. Worked real good.
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
First in line for the Sonex JSX-2T kit
Old 12-20-2009, 07:03 AM
John Myers's Avatar
John Myers John Myers is offline
We did my instrument panel and sub panel along with a few side panel items in our 8. No problem with glare. I used an old Briggs and Stratton intake valve with some scotchbrite super glued to the head and chucked in a drill press. Laid out a cross hatch pattern on the panel with a sharpie, then began, overlapping 50% with the turning. After finishing, I cleaned with a final prep cleaner and sprayed it with a Clear coat. I suggest a little practice on some scrap or even the back side of the panel first.
John
Old 12-20-2009, 12:51 PM
CESSNADON CESSNADON is offline
A friend of mine engine turned his firewall. To maintain the pattern, he build a wooden frame to hold the firewall and drilled index holes along the X and Y axis. He then pinned the frame to a sub frame which was clamped to the drill press, moving one hole at a time. The finished product was a work of art. Success is dependent on maintaining a precise pattern. I believe he used a small wire brush either bare or with a round of Scotch brite.
Engine turning was quite popular in the '20's and '30's but is probably too labor intensive for today's world
Old 12-20-2009, 03:35 PM
Noel Simmons's Avatar
Noel Simmons Noel Simmons is offline
Default about an hour per sq ft
you will want to turn the entire panel before cutting holes or your patter will get off. Use a guide to slide the panel down to keep the lines strait and the frequency will need to be done by eye.
Noel Simmons (repeat builder) just ordered my 40th it's an 8!
406-538-6574
A&P CFI EAA Tech/EAA flight adviser
