Old 12-19-2009, 03:17 PM
algrajek algrajek is offline
Default Dynon Pitch servo installation(RV8)
I am building an RV8(-1kit). I am attempting to install the Dynon Pitch servo, and the instructions tell you to remove the Vans Bellcrank brackets and replace them with the Dynon Brackets. The problem I have is in the newer kits, there is no "Bracket" to replace. The bellcrank mount is part of the aft Baggage rib assembly.
Has anyone come across this yet? Any fix?
Al Grajek
Al "Nordo" Grajek
repeat offender
\___(0)___/
RV8
RV8A
RV8
RV6A
Now RV7A!!
Old 12-19-2009, 06:36 PM
lancef53 lancef53 is offline
If you call Dynon tech, they can email you a link to a builder website that made it work. Basically all you need to do is radius the aluminum angle mount so that it nests in your formed bracket.
Easy peasy!!
http://www.mykitlog.com/users/catego...&category=4100
RV-8 108LF
