After reading some threads, it seems like HVLP is the way to go for priming. I started looking at various guns and ended up confused again. I plan on using Stewart Systems EkoClean, EkoEtch, and EkoPrime Primer/Sealer.
Does the Cleaner and Etcher get applied with a rag?
For the primer/sealer, which HVLP gun would I use?
I saw
here a decently priced HVLP set with a primer, top coat, and touch-up gun. Will this primer gun work well with the EkoPrime? Is the 1.8mm the key factor for primer guns?
The compressor is a CH 60 gal, 11.5 SCFM @ 40 PSI, 10.2 SCFM @ 90 PSI.
