12-18-2009, 10:14 AM
structural blind rivets for 3/32 dimple
Is there a type of structurally-sound blind rivets that will fit into a #40 dimple? They would have to be long enough to replace AN426 3-7 rivets. It's for the aft corners of the upper forward fuselage skin, where I absolutely cannot get a bucking bar up under the canopy deck.
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
12-18-2009, 11:11 AM
slide a thin piece of steel between the skin and angle
the heavy aluminum angle can act as the bucking bar mass... i slipped a thin piece of steel between the skin and the angle to drive the tail into. not ideal but you can drive a -3 rivet and get the aluminum flowing pretty easily. for the steel i took a heavy razor blade, shaped it a bit and put a bend on the end and picked a rivet that stood proud to start driving... worked fine.
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
12-18-2009, 12:21 PM
cherry rivet number
CR3214-4- is a 1/8" rivet with a 1097 (3/32" flush) head. Send me a PM and if I have them I'll drop a few in the mail. Grip length is "maximum" as in -4 is up to 1/4" from any thing over 3/16"
AWM
Reason: diminsion corrected
12-18-2009, 01:40 PM
Thanks! Do these require a special puller to pull, or will a regular blind rivet puller work?
I ended-up trimming the bottom flange of the canopy deck back to make room for my tungsten bucking bar. But good to know about these Cherry rivets in case I can't get all the rest of them along that row, around the sub-panel.
Phil
RV9A (SB)
Ottawa, Canada
12-18-2009, 03:51 PM
A regular
puller will work.
AWM
12-21-2009, 06:00 AM
Anybody know where the CR3214-4- rivets can be purchased? I cannot find them on Spruce.
Phil
RV9A (SB)
Ottawa, Canada
12-21-2009, 08:07 AM
Rivets
You can buy them at General Aviation Hardware Company. See http://www.gen-aircraft-hardware.com/
Small packages are available; suggest you give them a call.
They've also got a free offer this month for their excellent reference book/catalog. See http://www.vansairforce.com/communit...ad.php?t=51336 for the offer codes
Mike
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
12-21-2009, 08:16 AM
We stock them in packages of 10, and 100
We stock them in packages of 10, and 100 ,in our site search CR3214-4
I see your from Canada, the total cost to get them to you would be less if you have a US shipping address.
You could order on the webstore, there is a handling fee for Canadian orders less than $100. So if you see anything else you need that will help a bit.
If you want to e-mail our international sales person, the address is
mailto :intl@gen-aircraft-hardware.com
I used these in several areal while building my 6.
I hope this helps you solve your problem.
12-21-2009, 08:21 AM
Thanks for the promotion.
Originally Posted by Transporter
Mike, Thanks for the promotion.
There is a common misnomer out there, we are GENUINE, someone else is General.
I really appreciate your beating me to the response by just minutes and did a wonderful job promoting our company and products.
Its all part of "Helping Aviation Stay Together"
