12-17-2009, 05:27 PM
Crankshafts
I am building the engine for my 9A and the crank would not pass SB-505.
I know it really doesn't have to for an experimental, but I would sleep better knowing it doesn't have pits on the inside of it.
Mike at Rick Roman's said mine would be fine for an experimental and it only had a few pits left after grinding the bore out to the max, he just couldn't certify it.
Do any of you now fly with a crank that isn't certified, IE: won't pass the service bulletin?
Do you trust it?
Don Jones
Technical Support Manager
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
12-17-2009, 05:50 PM
Crank
Do you trust it?
Whatever gives you a warm fuzzy feeling over the mountains  ------
If you fly 200hrs. per year, It'd probably be good till TBO..........But if you want to sell it, you're obligated to tell the buyer and it will reduce the value more than what it will cost you to replace the crank now.
My two cent's worth.
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
12-17-2009, 06:33 PM
Use it for an Air-boat.
We should all require an airworthy engine. It the crankshaft exceeds the limits and cannot earn that Yellow Tag then don't use it.
Who wants a crankshaft failure with family on board? For me, the words experimental are for the Airframe. Crankshafts are the foundation of your engine and they should be yellow tagged (factory serviceable) or new.
Never skimp on your engine, fuel system or propeller. The upholstery?..sure..the paint scheme?...ok...
JMO
12-17-2009, 06:42 PM
I say use it, go with a wood prop or a Whirlwind and you will never approach the stress limits with a slightly pitted crank. I will bet there are a bunch of GA airplanes flying around with unknowingly pitted cranks.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
12-17-2009, 07:51 PM
Call Aircraft Specialties...
They have a repair process for the 505. I had my crank fixed by them and yellow tagged. Cost $175.00 if you have other work done to the crank and $250 if they only repair to the 505.
Just re-read your original post. I guess if Rick Roman's ground it already and there were still pits that were too deep I guess your out of luck. If their that deep, you might want to sell it to the airboat guys. You might want to send it to Aircraft Specialties anyway to get a second opinion.... New cranks are off the chart expensive and good used ones are rediculous high as well.
12-17-2009, 09:36 PM
It's actually funny....
So far I have called 3 or 4 certified aircraft parts suppliers including AERO and all of them have a couple of non- sb-505 cranks they would be happy to sell you for amounts from $1500-$2800 bucks. I can get a new ECI from Dallas for $3800. Seems weird they are selling un-airworthy parts even if you tell them it is for a certified application----What's up with that?
I actually found a smoking deal on a yellow tag, PID (SB-505) crank in Alaska. I just can't bring myself to roll the dice and send the money to someone advertising on Craigslist. Especially since he only wants $1700 for it
Don Jones
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
12-17-2009, 10:42 PM
O-320 SB-505
Does 505 apply to 150HP engines? Or is it just 160 HP?
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
12-18-2009, 07:26 AM
SB505
The AD & SB paper work that came with my used o-320E2A 150HP engine shows compliance with SB505.
Don't know if it was required for this engine but I'm glad it passed.
Dave
-9A finish kit
N514R reserved
12-18-2009, 10:25 AM
The Lycoming SB...
...is applicable to all O-320's and O-360's without a solid crank...
http://www.lycoming.textron.com/supp...dfs/SB505B.pdf
The FAA's AD has a different applicability...
AD 98-02-08
Textron Lycoming: Amendment 39-10291. Docket 94-ANE-44.
Applicability: Textron Lycoming 320 series limited to 160 horsepower, and 360 series, four cylinder reciprocating engines with fixed pitch propellers; except for the following installed in helicopters or with solid crankshafts: HO-360 series, HIO-360 series, LHIO-360 series, VO-360 series, and IVO-360 series, and Models O-320-B2C, O-360-J2A, AEIO-360-B4A, O-360-A4A, -A4G, -A4J, -A4K, -A4M, and -C4F. In addition, engines with crankshafts containing "PID" stamped on the outside diameter of the propeller flange are exempt from the inspection requirements of this AD.
http://www.airweb.faa.gov/Regulatory...5?OpenDocument
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
