I cut out the oblong holes for the landing gear mounts on the forward bottom skin of the fuse. I can only get one gear mount thru a hole-either the right or left but not both at the same time.
My question is do I either enlarge the oblong holes so they both fit, or, settle with only one mount going thru the hole then try to wiggle the other landing gear mount into place thru the other hole while the skin is in place.
I hope I am making myself clear. I have been fiddling with this-another time grab that slows progress. Been getting a lot of these lately.
I photocopied the plans with the hole and cut it out, lined up the rivet holes and marked the cutout lines on the bottom skin with it clecoed on the fuse. I also displaced one or two of the rivets aft of the hole to get better edge distance.Here is a photo of the finished cut:
Yes I aligned the template to cut the oblong holes. I also cut away the wing bulkhead flange to clear. Then I bolted the gear mounts in place. I also drilled the 5 bolt holes and the 2 screw holes into the side skin structure for the gear mounts. (I was hesitant to drill these holes now-the instructions aren't clear when to do this).
After getting one gear mount in the bottom skin hole at a time I unbolted the other gear mount then tried positioning it in place to get the gear mount stub thru the other skin hole. Couldn't do it so I guess I am resigned to get the file out and make the holes larger so the bottom skin drops down in place over the gear mounts.
[quote=jimbo;387368]Couldn't do it so I guess I am resigned to get the file out and make the holes larger so the bottom skin drops down in place over the gear mounts.
Jim, install the bottom skin before installing the gear leg mounts.
