Old 12-14-2009, 05:27 PM
helodriver's Avatar
helodriver helodriver is offline
Default I did my first Snow/Ice Landings today!
OK, I know it wasn't an RV, but it was truly a learning experience. Did a couple of Touch and Go's in a King-Air 200 today. It was kind of scary at first. There was more traction/control than I expected. The biggest tip was don't touch the brakes!! Sorry, I know its not RV related, but I had to share.
Terry
Terry H.
RV-7 Preview Plans
Gathering tools....
Project on hold while we raise 5 year old twins
Old 12-14-2009, 06:03 PM
jsharkey's Avatar
jsharkey jsharkey is offline
Default I Tried Some Phase 1 Snow Ops Too
The weekend before last I decided to see how my RV-6 would perform in a few inches (3 or 4) of unploughed snow. I was worried about the small wheels - and the wings & tail and other delicate parts being so close to the ground and the blizzard of snow created by the prop on take off. However the only problem was that I couldn't hold 1700 rpm on the brakes during the pre-flight mag checks and had to make do with 1500 rpm instead. The cold, dense and dry air must have compensated for the extra snow drag because take-off wasn't noticeably shorter than usual but the landing roll was very short with no bakes needed - or desired.
Which reminds me I need to post a comment on the cold oil temp discussion
Jim Sharkey
RV-6 Phase 1
Old 12-14-2009, 06:09 PM
Norman CYYJ Norman CYYJ is offline
Be very careful landing in that depth of snow if it warmed up and re-froze. You could possibly flip over when you break through the crust. Have fun in the cold, great performance numbers.
Old 12-14-2009, 06:23 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Another concern is getting snow in the wheel pant area, freezing then causing problems upon landing.
Old 12-14-2009, 07:19 PM
Geico266's Avatar
Geico266 Geico266 is offline
I'm going flying in the am to test out my cold weather mods on the -12. Should be around zero F. Thanks for the tips.
It's fun to be the first one to land on fresh snow. Do a T&G and see if you can get the wheel in the same tracks next go around. That will keep you humble. OH! and watch out for the snow plow!
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 12-14-2009, 09:06 PM
terrykohler terrykohler is offline
Default Making Tracks May Not be a Good Idea
Larry:
While you probably have a great deal of experience with winter flying, many of the readers of these forums may not have that advantage. Around the Great Lakes, it's not unusual for snowfall to vary more than six inches over a distance of less than 25 miles. Taking off from an uncontrolled airport and making tracks in an inch of (known) dry powder is a lot different than dropping into a field with four to six inches of wet snow on the pavement. Not recommended. Even on relatively "clear" pavement, it's not unusual to have very poor braking action - a potentially big problem, especially in a crosswind.
Winter takeoffs and landing from any field where there's limited snow removal, sanding, and braking action reports is a high risk proposition. Throw in torque, p-factor, lack of ABS, lack of reverse thrust, and a single engine and the risk is even higher.
Call ahead, ask for runway conditions, and ask what type of AC have been taking off and landing. Then assess your own skills. Just trying to keep everyone safe.
Terry, CFI
RV-9A N323TP
Old 12-14-2009, 09:18 PM
videobobk's Avatar
videobobk videobobk is offline
I remember my first landing on a frozen lake. Phantom U/L, touched down nice (hey, you know it's level and smooth) and was feeling pretty good rolling out. Then I figured out I had to stop before I hit the rocks on the shore. No brakes, it won't steer, nothing worked. Finally I kicked full right, gave a blast of throttle and spun around. Another blast and I was stopped. From then on I shut off the engine when I touched down. Nothing would stop it with the engine running! Won't be trying that in the RV...
Bob Kelly
Bob Kelly, Scipio, Indiana
Tech Counselor
Founder, Eagle's Nest Projects
President, AviationNation, Inc
RV-9A N908BL, Flying
Old 12-14-2009, 09:38 PM
Andrew M's Avatar
Andrew M Andrew M is offline
Default Frozen brakes
The other risk of using brakes is melting and refreezing water, locking the wheels. I fly on straight skis in the winter, sometimes I have had to keep flying/take back off for better crosswind control. Landing in my own tracks is mandatory, first landing to drag the lake and see if there is overflow for the next time arround, and tracks to take off in if the snow is much over 20 inches.
Yesterday I was trying to get the pre inspection power run numbers on a Caravan (650HP). Dragged the ice grates 300 ft brakes locked, steering with rudder mostly. FUN!
AWM
Old 12-14-2009, 09:49 PM
rocketbob's Avatar
I don't remove my wheelpants in the winter, and frequently fly of our grass strip with 2-3" of snow. If there aren't any drifts I can fly, otherwise I work on the rocket. I've had the wheels freeze up and its a non-event, they break loose easily.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 12-15-2009, 05:59 AM
jsharkey's Avatar
Default Good Advice!
Thanks for that one.
Jim
