I am practicing my tig welding for an exhaust that I am building and need some .040 ss rod . The welding shop only sells it in 10 lb box for $ 175 . Will041 saftey wire work for welding 304 .049 thick tube ???
I've used 1/16 308 Stainless tig rod to weld mufflers. You might check with a small welding shop or tool and die shop. I bet they would give you enough to do the job, I know I would if you were close.
Jim Wright
RV-9A N9JW 90919 SoldArkansas http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
