Well, I would say that no picture will be able to help describe if the edge deburring is sufficient, but here is my test: Can you rub your finger along each edge (both sides) and not feel a sharp edge? If so, that is good. If you find a spot that if rubbed hard enough could cut you, give it another pass.
Scott Card
CMW E-Lift
