Old 12-14-2009, 09:02 AM
shiney shiney is offline
Default Tacho Transducer question
My set up is one Slick and One Lightspeed, will the Vans tacho transducer (Part Number = IE VTACHGEN 2) work for this set up (reading through GRT-EIS4000) or do I need an alternative? I came across this posting on the site;
http://www.vansairforce.com/communit...cho+transducer
Emp painted, wings painted, finishing the fiberglass work on the fuse and then ready for painting.....
Old 12-14-2009, 09:31 AM
AZtailwind's Avatar
AZtailwind AZtailwind is offline
Default nothing to do with ignition type-
The Vans VTACHGEN 2 transducer is taken out off the accessory case from the mechanical drive Port. GRT pickup may also work with this: Has nothing to do with ignition choice though. The GRT manuals leave many questions-maybe call em up- hope that helps....
Brad Ransom
http://www.westcoastravens.com
RV-6A 180HP-acquired
RV-4 180HP-acquired
Old 12-14-2009, 09:35 AM
Radomir's Avatar
Radomir Radomir is offline
That one works just fine with GRT's EIS... I have the same thing, but with the 12" extension cable (also available from Van's)... no issues.. works as expected..
Radomir
RV-7A sold
Old 12-14-2009, 09:58 AM
Default Mag drop
Thanks guys, does it pick up the Mag drop from the GRT and Slick? I'm sure I read somewhere that I needed to do something with the set up to get both mag readings but I can't remember what I read!
Old 12-14-2009, 10:37 AM
Radomir's Avatar
You do not need to do anything.. this reads RPMs right off of the engine (camshaft rotation), and doesn't care which ignition is on...
PS.. You'll need the one with 12" extension if you have an angle oil filter adapter.. (or a vacuum pump)
Radomir
RV-7A sold
Old 12-14-2009, 11:05 AM
Default Great
Thanks again Radomir, as always, you're a great help.
Martin
Old 12-14-2009, 11:17 AM
Fearless's Avatar
Fearless Fearless is offline
Default Thanks as well
I'm at the point where I need to think about firewall forward wiring and plumbing and I plan on using a GRT EIS 4000 system on my plane. This post was quite insightful for me as well.
Mike
RV-9A Based K6I2
Flying - out of Phase 1
Building RV-12 with brother
