Old 12-14-2009, 06:32 AM
Flyguytki's Avatar
Flyguytki Flyguytki is offline
Default Why no Pants for a first flight??
Something that I have always wondered is why are all first flights conducted with no wheel pants on??
RV-7 N87DX Built, Flown, and Sold!
Old 12-14-2009, 06:34 AM
Geico266's Avatar
Geico266 Geico266 is offline
A little more drag to work the new engine?
The builder is anxious to get in the air?
Easy access to see how the brakes are doing?
The model you build does not have them available yet?
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 12-14-2009, 06:40 AM
caryr's Avatar
caryr caryr is offline
So you don't trash them on the first goofed landing
Cary Rhodes
Taylorsville, Georgia
N203CR
Van's RV-7
First Flight April 2004
Old 12-14-2009, 07:20 AM
Default Your data are inaccurate
My first flight had all fairings installed.
Bob Axsom
Old 12-14-2009, 07:32 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Bob Axsom
Mine too - once I was flying, I knew I'd never be able to stand taking the plane down to do a bunch more work on it. I took the extra couple of weeks to finish the pants and fairings before first flight, and was glad I did. The month it went into the pant shop later on was agony!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 12-14-2009, 08:06 AM
Jamie's Avatar
Jamie Jamie is offline
Well, it's in the build manual so I think that's probably why a lot of folks do it this way.
I think it makes sense to me. Fairings are for going fast. If you are breaking in a new engine you will run wide open for the first 10 or so hours.
I also wanted to fly without them to see if my airplane flew *really* straight. If it flies straight without fairings then you *know* that you built a straight airplane. If it flies with the ball off center and you have all of the fairings installed how do you know the problem isn't simply a matter of a crooked gear leg fairing?
Yeah, with or without fairings would work but there is absolutely no advantage to flying the first flight *with* the fairings but there are several (albeit small) advantages to flying without them. Note that flying without the fairings does not necessarily imply that the fairings aren't finished.
Old 12-14-2009, 09:12 AM
dmaib's Avatar
dmaib dmaib is offline
Exactly. I had mine finished and ready to go, but left them off for Phase 1 for all of the reasons mentioned. On my first flight with them installed and with a shiny new paint job, I was astounded at the difference in IAS. 12 to 15 knots!
David Maib
RV-10 N380DM
New Smyrna Beach, FL
VAF Paid 1/21/2020
"In '69 I was 21, and I called the road my own"
Jackson Browne
Old 12-14-2009, 09:56 AM
DanH's Avatar
DanH DanH is offline
Because you should wear a nomex flight suit instead?
Because it helps you stay cool and dry?
Because you're starring in a really weird reality show?
Dan Horton
RV-8 SS
Barrett IO-390
