I'm looking for the best resource of info for Brake lines and fittings, Fuel lines and fittings, Pitot/Static lines and fittings.
What I'm looking for is applications for each. How to use each fittings? Do you need inserts for the fitting you're using? When is a lube or sealant jell required for sealant?
I have a pretty good idea for each of these but I would like a written practice of what is required. There are a lot of opinions out there and I would like something I can refer to for each.
Looking at the EAA sport magazine last month I read a article which points towards FAA Pub 43.13-1a & 43.13-1b which is for acceptable methods, techniques and practices. Does anyone have this pub and is it a good resource?
Thanks for your input!
Greg
