Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 12-13-2009, 04:52 PM
Ron B. Ron B. is offline
Default 696 verses GDU 375
We would like to purchase a GDU 375 for our RV-10 that is being painted. The only reason we are looking at a GDU 375 is that it is panel mounted. The 696 has the features we want but we find the panel mount model looks nicer. Does anyone know if the GDU 375 has all the functions that the 696 has. We are aware the GDU 375 is expandable or will be in the future and have EMS and EFIS capabilities. We are not interested in this as we are ordering dual Skyviews tomorrow.
We have a Zaon PCAS XRX that we want to have connected to our GPS , will the GDU 375 also connect? Do both units have flight charts that will disable in six months if not updated? We are using 396's now and don't upgrade our units and they still function well as they are. Will the 696 and GDU 375 work the same?
Thanks ron
Old 12-13-2009, 06:08 PM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
Default just panel mount the 696...
the 696 is really easy to panel mount... you just need to make the cutout and use the built in attachment points on the back of the unit for the ram mount to tie into the panel. my setup is much more involved than is necessary to simply mount the 696 but the idea should be clear. i used z-channel to stand off the 696 and nested the legs into angle faced to the panel where i have anchored the radio stack and braced the sub-panel.
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
Old 12-13-2009, 09:26 PM
newtech's Avatar
newtech newtech is offline
Like Stephen said, the 696 is very easy to panel mount. I used Stein's method; just screw a piece of aluminum with four stand-off's to the back of the GPS and use the stand-off's to mount the GPS to the panel. Four screws and it can be easily removed from the panel through the cutout.
______________________
Steve Eberhart, W9JUQ
3EV - Evansville, IN
Where is Steve and the Sky Terrier?
RV-7A Slider, O-360 A1A, Catto 3 blade, 2 screen Garmin G3X Classic, GTN 650, Bionics APRS. FLYING since June 24, 2009
EAA Chapter 21
Old 02-04-2010, 08:24 PM
flickroll's Avatar
flickroll flickroll is offline
The 696 mounts fine in the panel with a home made mount and standoffs ala Stein.
The biggest problem however is access to the data card slot. Garmin will very soon roll out geo-referenced approach plates. If you wish to use this feature and keep the database current, you'll constantly be removing the unit from the panel for updates. A PITA for sure....
Jim Shannon
RV-8 N52VV
Charlottesville, VA
AFS 4500 EFIS & 3400 EFIS/EM
G430W - SL30 - G327 - G696 - G240
TT DigiFlight II VSVG w/pitch autotrim
VP-X Pro
Old 02-04-2010, 08:52 PM
newtech's Avatar
I originally mounted my 696 using Stein's method because I didn't want to spend the $200 for an Air Gizmo mount. Every time I connect it to my laptop to download the flight log data it has to be unscrewed from the panel. If I were buying it today I would spend the extra and get a GDU 375. Since I already have the 696 I am going to replace my panel mount with the Air Gizmo one.
EAA Chapter 21
Old 02-04-2010, 09:33 PM
flickroll's Avatar
I have a 696 and am starting a panel redo. I think if I stick the 696 in the left side of the panel using my home made mount, I'll be able to reach up behind the unit and work an SD card into the slot. Will probably take double-sided tape on my finger to hold the card during the maneuvering process, but I think it will work. If it won't, and I decide to keep the 696 in the panel, I'll explore a 375. But that sucker is $4k, not including antennas!
One good thing about the 696 that the 375 does not have is the battery which will keep you navigating if your electrical system goes TU. If you want a backup battery for the 375 it's even more moolah.
Jim Shannon
RV-8 N52VV
Charlottesville, VA
VP-X Pro
Dan Langhout's Avatar
Dan Langhout Dan Langhout is offline
Default Close but not the same . . .
I've got a GDU-375. A buddy has a 696 and we got the two of them together to see what the differences were. We didn't do an exhaustive comparison but we did look enough to see that they weren't identical. Examples - the 696 will let you put two lines of data across the top whereas the 375 will only let you put one. The 375 weight and balance stuff shows you a graph whereas the 696 won't. It seemed to us that all of the major, really important stuff was just the same. If there's a specific feature you want to check on the 375, let me know and I'll take a look.
Dan Langhout
2020 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
665 hours and counting . . . .
Now based at Moontown (3M5)
Old 02-04-2010, 09:35 PM
SteinAir SteinAir is offline
You guys are forgetting the real little/simple trick that makes mounting them with standoffs even easier. Slot two of the screw holes on one side all the way to the "big square hole" and instead of removing all 4 screws, you only remove two of them, loosen the other two and slide it out, shouldn't take long at all.
I wish I could take credit for it, but again it's a little bit of ingenuity that Younkin came up with...
Stein
Old 02-04-2010, 09:54 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Email me... We have the right people, with the best of talent to build your panel... Garmin or whatever without feeling violated by exorbitant labor cost. Even silkscreen is available without having to bend over.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 02-06-2010, 01:55 PM
dtaylor dtaylor is offline
Aside from the 696 being way cheaper, one other advantage is you can pull it in and out of the panel to practice with it easily. (I have an Airgizmo mount which works great.) This alone is worth a million dollars to me. These things are fairly complicated now and they require x amount of time to learn them fully -- and stay current with them!
