12-13-2009, 01:32 PM
Need help with a decision
This paint or paint/polish question could likely fall under the never ending debates.... but I'm going to pose my dilemna none the less.
I'm building a -7. I have decided to go with Stewart's as I can do it in my garage without killing myself, my wife, kids or neighbours cats.
To paint I need : HVLP gun, paint, experience, big booth
To polish I need : electric polishers, polish compound, elbow grease, small booth to paint fiberglass parts.
Will use vinyl accents to decorate.
To polish is cheaper I think, takes the same amount of time as painting (ie. paint prep work). Polish is lighter, looks good but needs yearly maintenance. \
Here's a picture I like: http://www.pilotbill.com/Black-SilverRV.jpg
My big thing is this... I can put in my best effort with the paint and screw it up and be pissed at the result. With polish, as long as I dedicate the time, I can be assured of the result.
Why did you choose to paint or paint/polish ?
Darren
12-13-2009, 01:54 PM
With polish, you'll need to repeat the process every few months - probably 2-3-4 times a year, depending on how shiney you want the airplane. I think it would get old taking a couple of days to polish the airplane that frequently.
One thing to consider is whether you've ever run a polisher before. It isn't hard, but is possible to make a real mess with one. A bonnet grabbing an 0.020 or 0.032 skin can bend an edge badly.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
12-13-2009, 02:28 PM
You will never, ever, be on a heading without a blinding, cooking reflection off the wing. Ever. Even at night.
John Siebold
12-13-2009, 04:07 PM
For those who painted their own RV's, with Stewarts, and didn't have an abundance of experience, how did you learn ?
Does the sun really bother you in flight all the time ? The wings are always moving around, so isn't the sun reflection just a bother at certain times ? Unlike standing next to the wing on the ground where I know you can fry yourself.
Does it take an average of 50 lbs of paint to do an RV-7 ?
Thanks for the input. I have to decide here shortly whether to order from perfect polish or more paint from Stewarts.
Darren
12-13-2009, 04:38 PM
Darren
Hi Darren,
I just finished painting (a couple months ago) with Stewart Systems paint. It was my first "real" paint job, although I painted some motorcycle fairings a year ago with PPG Omni. The 2 systems are pretty different, so I don't think my experience with the PPG helped. Painting is a BIG job, regardless of what system you go with...but in the end it's worth it. I would recommend not following my lead and going with a paint scheme that's overly complex. But that doesn't mean you should settle for all white or something very simple, either.
I re-weighed my airplane after the paint was finished and I added exactly 50 pounds, but my "pre paint" weight didn't include wheel fairings/pants, nor did it include my interior side panels. I'm guessing paint was responsible for about 30 pounds of the added weight.
Lastly, I would think the polished aluminum would blind you a lot more than paint...but it would probably only be at certain angles from the sun when it's lower on the horizon.
Sonny W
Boise, Idaho
RV-7A Flying!
12-13-2009, 04:41 PM
I had this decision made before I ordered the tail kit. I know for a fact that I can paint my plane myself, but I also know for a fact that I will have a big learning curve before being able to make it look good. I've seen a couple of really well-built airplanes that looked like junk because of a bad paint job. I never thought twice about it, honestly - Grady is gonna have a chunk of my disposable income as soon as Phase I is over.
I'm putting a new engine, new prop, and new glass panel in the airplane, I might as well drop some money on a good paint job as well.
12-13-2009, 05:08 PM
Oh geez! I suppose if money were no object then most everyone on here would have a professionally done paint job!  As a matter of fact, if money were no object, I'd probably be building a Viperjet (or flying one already built).
Sonny W
Boise, Idaho
RV-7A Flying!
12-13-2009, 07:13 PM
My Same Dilemna
I was hard over on a polished airplane, until I discovered too many scratches too deep on the elevators and rudder. So perhaps painted control surfaces and polish elsewhere?
I haven't made the final decision yet. Polishing with a cyclo polisher is not hard and I think I'll start there. The rest of the airplane is pristine and should look great polished.
After flight test, if I hate it, I'll paint it all. Easier than stripping a painted airplane to get it shiny.
I think I would have to pay to have mine painted. I painted the leading edges of my Bonanza cuz some paint peeled off. Painting was easy... sanding all the orange peel took days of mind numbing labor. I am NOT a painter. It's an art.
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
12-13-2009, 08:42 PM
Thanks for the opinions fellas. Keep them coming.
I don't want to send my bird out for paint. I've done the whole dang build myself, I kind of want the bragging rights of saying I did it ALL
Sonny, did you use a HVLP turbine for your Stewarts Paint ? I just read that the HVLP turbine gun I just bought may not work well with the water based paint.
For those who painted their planes before the first flight, would you recommend painting smaller parts and then doing the final assembly ? ie. do elevators, then Vertical stab, then one wing at a time and then the fuse. Or bolt it all together and then go spray crazy ?
For those who polished, anymore comments of the sun reflecting and blinding a pilot during flight ?
I read that Nuvite can get out some pretty deep scratches. Anybody with first hand experience ?
Anybody out there started to polish their plane and then gave up and went painted ? If so, why did you give up ?
"Airguy" your comment on having a well built RV with a junky paint job is my BIG reason for this post. I don't want to be another statistic !
Thanks again all for the help, still deciding,
Darren
12-13-2009, 08:45 PM
I'm building an airplane, not restoring a motorcycle. This project has a budget like any other, but it also has the potential to kill me in a rather messy manner. It will be done right, or not at all. Sorry if your views differ from mine...
