Old 12-12-2009, 12:00 PM
Tram Tram is offline
Default Charging.. Seems simple.. What am I missing?
OK guys..
Maybe some of you have seen my off the wall questions - we did not build our 6 so there are some things that the builder did that is leaving us scratching our head..
I am trying to track down an some bugs in our strobes.. Sometimes they work.. Sometimes they don't..
I'm almost to the point of pulling the entire panel and redoing it just so I know what is what.. Many of the leads are labeled in a fashion that is starting to "disappear" (read masking tape with "Strob Pax Sd" written on it..)
Anyway, we came across a lead that is on a bus - one side running to the + side of the battery.. The other side of the bus is "12v Bat for Charging."
So.. There is a "terminal" for the positive, where would I ground the charger? Anywhere on the frame?
I'll probably slap myself when someone answers this, but I'm puzzled.. LOL..
Thanks again!
Jeff
Old 12-12-2009, 12:51 PM
chaskuss chaskuss is offline
Jeff,
Yes, you could place the negative lead of your charger anywhere that you could obtain a good ground. Providing that the builder followed the recommendations of THE AEROELECTRIC CONNECTION, there should be a central grounding point located on both sides of the firewall. This would be the ideal place to mount the negative lead of the battery charger. A photo of the single point ground can be seen here.
http://www.aeroelectric.com/Pictures...ng/gnd_bus.jpg
It will have a lot of ground wires running to it.
Charlie
Old 12-12-2009, 01:29 PM
Charlie-
Yeh, we have the grounding post on the firewall.. I thought that might a sufficient place to ground, but before I went crazy I thought I'd check and make sure..
Thank you for the reply!
Jeff
Old 12-12-2009, 01:46 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
In my 6A, I have the right side "cigarette lighter" type receptical connected to the hot side of the battery with a fuse. My charger has the other end on it's hot lead, and the normal alligator clip for the ground. I just latch it on to a bolt that holds the landing gear leg in place. The lighter receptical is used for the passenger headphones during normal operation.
L.Adamson --- RV6A
Old 12-12-2009, 04:48 PM
Default A simple tool
Originally Posted by L.Adamson View Post
In my 6A, I have the right side "cigarette lighter" type receptacle connected to the hot side of the battery with a fuse. My charger has the other end on it's hot lead, and the normal alligator clip for the ground. I just latch it on to a bolt that holds the landing gear leg in place. The lighter receptacle is used for the passenger headphones during normal operation.
L.Adamson --- RV6A
Larry,
Your post jogged my memory of a small tool I purchased for working on cars. [I own a small auto repair business] With this tool, you could easily charge your plane's battery, assuming you wired the cigarette lighter receptacle to the battery bus. This tool plugs into the cigarette lighter receptacle. It has a small light to indicate that you have power and ground. It also has two posts, where you could connect a small battery charger. See
http://www.lislecorp.com/tool_detail.cfm?detail=496
It's also very handy for doing electrical troubleshooting on vehicles with cigarette lighters. I generally use it for easy access to vehicle power and ground when using a test light or VOM. You should be able to find this tool at your local auto parts store or local mobile tool vendor. I got mine from my local Cornwall Tool dealer.
Charlie Kuss
Old 12-17-2009, 07:03 PM
Ok guys.. I hate to sound unknowledgeable, but you have to learn somewhere.. I guess I just do not understand exactly what is going on with my airplane..
Was out in the hangar today and tried to run the charger to the wire listed as "12v + Bat for Charging" and then ground via the ground post.. I also tried to ground on the exhaust and other parts of the frame.. I got nothing.. I am unable to get the charger to charge.. The charger faulted and told me I had it hooked up incorrectly.. Bad connection..
I think, regardless of this post LOL, I am pretty handy with electrons.. I fly all electric remote control aircraft, several making over 150amps and 5000watts.. and until this even thought I had a pretty good handle on how electrons flowed..
Anyway, I may pick up one of the above tools.. Seems pretty handy, I could easily wire up an adapter for my charger to use it..
Anyone have any idea where I may be boning this up?
Thanks guys
Jeff
Old 12-17-2009, 07:50 PM
Norman CYYJ Norman CYYJ is offline
Try turning on the master switch. It is possible that the guy that built the plane put the charger wire on the buss side of the master solenoid and not the battery side. Just a guess.
Old 12-17-2009, 07:57 PM
L.Adamson's Avatar
As I remember, electrons actually flow from negative to positve..........yet we design everything by going from positive to negative. I still haven't figured that one out. Or maybe I just remembered wrong..
L.Adamson ---- RV6A
Old 12-17-2009, 08:03 PM
Caveman's Avatar
Caveman Caveman is offline
Jeff, Have you tried just hoooking the charger up directly to the battery posts? Does the wire labeled "12V Bat for charging" have a switch installed that needs to be closed? I believe some people wire their aux power this way. Pictures would help us have a better idea of the system.
Joe Schneider
RV-7, IO-360, BA Hartzell, N847CR
Flying since 2008
Old 12-17-2009, 08:07 PM
Yeh, I'll give that a shot.. My 12v "cigarette outlet" is only hot with the master on..
LOL.. I guess you are right.. See.. Told you I only "thought" I had it figured out..
Oh yeh, works like a charm.. I'm just looking for a way to be able to charge it without doing the circus act of crawling under the panel, taking off the case and taking it all apart..
