Old 12-07-2009, 07:16 PM
Brian Vickers Brian Vickers is offline
Default Oil pressure sensors - why not screw directly into engine?
Education needed
Why is it bad practice to screw the oil pressure transducer directly into the accessory case? I am about to do what appears that everyone else does and mount the oil pressure sensor (VDO brand) OFF of the engine (not on the engine). It would sure be nice to screw it into the appropriate hole in the accessory case instead of routing hoses and mounting the sensor. The steel AN oil pressure hose fitting from Vans has a restrictor hole, just like the sensor. Is the issue direct engine vibration and therefore shortened service life? Transducer break off and cause catastrophe? The Firewall Forward book says ?the electric sensor is screwed into the engine.? Sorry for such a basic question but my search of the archives didn't turn on the light bulb. I'd sure like to know what caused the trend toward remote mouting.
Brian Vickers
Bainbridge Island, WA
RV4
Old 12-07-2009, 07:22 PM
rv6rick's Avatar
rv6rick rv6rick is offline
JOAT-MON & Moderator
Hi Brian,
Yup......you answered your own question.
Giver 'er a shot....let us know how you make out .
Originally Posted by Brian Vickers View Post
Education needed
Why is it bad practice to screw the oil pressure transducer directly into the accessory case? Is the issue direct engine vibration and therefore shortened service life? Transducer break off and cause catastrophe?
Rick Gray in Ohio - Builder Assist Center - 50+ Awards & counting
BRONZE / SILVER & GOLD LINDY AWARD WINNING RV's & Rockets
EAA Oshkosh Homebuilt Judge/Tech Counselor/Flight Advisor / F.A.S.T. Formation Flight Lead
Kitfox/RV4/6/7/8/9/10/12/14?s
6 RV10's
2 Time Sun n Fun Grand Champion
F1 Rocket #1 Oshkosh Gold Lindy Grand Champion!
F1 Rocket #2 :-)
Fastback RV8 Slider
RV14 #2 in progress
53 RV's & Rockets & counting
Whirlwind Prop Dealer
Love my Pitts S-1S
Old 12-07-2009, 07:28 PM
rocketbob's Avatar
Best ask someone with a Jabiru...they've been doing it with success for years.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 12-07-2009, 08:07 PM
Yep, and they work ok on the Subaru block as well.
But an IA told me years ago don't screw it into a Lycoming block. Evidently, he'd seen one break resulting in a gross oil leak.
I believe it is prudent to use the Van's manifold.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 12-08-2009, 06:21 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Now that I have changed it to a remote mount, I can say that Louise's RV-6 had the sensor screwed directly into the engine (on one of the front oil gallery ports) when she bought it, and it was probably there for 19 years and 2500 hours without a problem. I moved it because we had a new (EFIS) sensor go erratic after about 50 hours, and I decided that it might have been vibration, so why not eliminate that possibility.
YMMV
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 12-08-2009, 09:03 AM
Default Remote mounting underway
Thanks guys,
Last night I had one of those pondering work sessions (no tools used). I'm going to remote mount it and move on. Thanks again for the comments.
Brian Vickers
RV4
Old 12-08-2009, 02:35 PM
David Clifford David Clifford is offline
Banned
My IO-540 V4A5 came out of a 2001 Maule and the Rochester oil pressure sending unit was screwed into an oil port on the accessory case. Seeing as how it was good enough for a certified plane application, I intend to leave it there for simplicity. I will locate the fuel pressure sender off the engine though. When we built the Cozy MKIV, we installed an AirWolf remote oil filter system, so It was a simple solution to mount it off the engine.
