Old 12-07-2009, 05:00 PM
dtaylor dtaylor is offline
Default Minimum Oil Temp Required
I am hearing that at least 180 degree F oil temp is required for at least 1/2 hour of engine operation to burn off all the water in your oil.
Is this true?
How important is this year around?
If I can only run my engine in the winter at 160 deg F max, will I build up water in my engine oil and cause corrosion?
Dave T.
Old 12-07-2009, 05:39 PM
Russ McCutcheon's Avatar
Russ McCutcheon Russ McCutcheon is offline
It is important, you can install a shutter from Van?s or just tape off half or so of your oil cooler in the winter. If it where mine I would do one of these to get the temp up over 180F.
Russ McCutcheon
@rv4welder on Facebook
russmccutcheon@gmail.com
We build many of your RV weldments.
Old 12-07-2009, 05:48 PM
AlexPeterson's Avatar
Default Time and Temperature
No hard fast rules. There is always water in the oil, the only question is how much. No magic temperature for the oil, but if the oil temperature is below the dew point of the exhaust blow by, you will be adding water to the oil. If it is above, you will be removing water. I am not sure of the dew point of exhaust gas, but I recall it being in the neighborhood of 140F.
Perhaps others more knowledgeable of this value will chime in. The larger the temperature spread between the exhaust dew point and the oil temperature, the faster the reduction.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 12-07-2009, 06:02 PM
rocketbob's Avatar
Just yesterday I changed my oil after doing some formation flying with some friends. I normally tape over the oil cooler in the wintertime to keep the oil temps up, but didn't get around to doing it until yesterday. For the duration of the flight, the oil temp was no hotter than 165F. I cut the filter to inspect it, and was surprised to find little silver looking things floating around in the oil. I use automotive filters and they have an anti-drainback valve, so there's a pint or better that stays trapped in the filter. The little silver things turned out to be droplets of water.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 12-07-2009, 06:13 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Default YES...YES...
If you're flying a Lycoming engine, no less than 180 for at least 30 minutes, Twice a month!!
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 12-11-2009, 10:08 AM
trib trib is offline
Hey RocketBob, what kind of oil filters do you use?
Tim Ribble
Virginia Beach
RV-6A (only took 13 years to build )
N621TR In unrestricted operation
Old 12-11-2009, 11:08 AM
terrykohler terrykohler is offline
Default Maximum Service Life
For max. life, the Lycoming manuals suggest oil temp at cruise to be 165 to 220 Fahrenheit.
Old 12-11-2009, 11:40 AM
rocketbob's Avatar
Napa Gold 1515
N8155F C150 flying
Old 12-12-2009, 09:45 AM
Steve Steve is offline
Default you may not get there
I usually tape off the front side of my baffle mounted oil cooler around Thanksgiving. The plane lives in a warmed (60F-ish) hangar. It was 15 degrees here in northern Utah and we decided to fly put for lunch. My oil temp never got above 160, probably closer to 150 (bottom of the green arc).
That's how it is. I've got a cool running engine. Summer oil temps rarely get above 190.
Five Sierra Fox
RV-9A
Utah
Old 12-12-2009, 10:21 AM
avi8tor50 avi8tor50 is offline
About to tape off my oil cooler. Was wondering what type of tape folks use.
Doesn't the heat of the engine and oil cooler melt the glue of the tape and cause it to slip off? I was considering using aluminum foil tape. Do you just tape off the front of teh baffle where the opening is behind the #4 cyliinder? Does anyone tape around the back of the oil cooler?
Any photos would really be appreciated!
Peter K
9A-99 hrs
