Old 12-07-2009, 08:13 AM
prkaye prkaye is offline
Default mag cap orientation
I'm trying to figure out the correct orientation for the connector that goes on the back of my mag. I have a slick mag, on the left (the right is a Lightspeed). One of the 4 output wires on the back of the connector is labelled with a "1" (the others are unlabelled). The back of the mag has the left side marked "L", the right side marked "R", and the bottom marked "X". See pics.
Two questions:
1) Which way does the connector cap get attached to the mag? There are three possible ortientations (three screws).
2) I presume the wire labelled "1" goes to cylinder 1. Which cylinders do the other wires go to?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 12-07-2009, 08:31 AM
Don Jones's Avatar
Don Jones Don Jones is offline
The cap will only go on one way when the wires are placed in the holes where they belong. The L & R markings are next to the holes where you place the timing pin.
Instructions Copied from Sacremento Sky Ranch Website
1. TIMING INSTRUCTIONS ARE ON THE OUTSIDE OF THE BOX.
INSERT THE T-118
TIMING PIN IN THE L OR HOLE OF THE DISTRIBUTOR BLOCK, DEPENDING UPON THE ROTATION OF THE MAGNETO. REFER TO THE MAGNETO DATA PLATE FOR MAGNETO ROTATION
2. TURN THE ROTOR SHAFT OPPOSITE THE SPECIFIED DIRECTION OF ROTATION UNTIL THE TIMING PIN IS INSERTED APPROXIMATELY 7/8" INTO THE DISTRIBUTOR BLOCK. WHEN PROPERLY ENGAGED, THE TIMING PIN WILL "SEAT" AGAINST THE DISTRIBUTOR BLOCK. NOTE: IF THE ROTOR SHAFT CANNOT BE TURNED AND THE TIMING PIN IS NOT SEATED 7/8" INTO THE DISTRIBUTOR BLOCK, REMOVE THE PIN. TURN THE ROTOR SHAFT 1/8" TURN AND REINSERT THE PIN. TURN THE ROTOR SHAFT 1/8" AND REINSERT TIMING PIN. THEN REPEAT STEPS 1 AND 2 ABOVE
3. WITH THE PIN FULLY INSERTED INTO THE DISTRIBUTOR BLOC,, THE MAGNETO IS NOW ALIGNED TO FIRE CYLINDER NO 1.
4. AFTER THE MAGNETO IS INSTALLED ON THE ENGINE, REMOVE THE TIMING PIN. PROCEED BY FOLLOWING ENGINE MANUFACTURER'S TIMING PROCEDURES.
Don Jones
Technical Support Manager
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
Old 12-07-2009, 08:35 AM
Lycosaurus's Avatar
Lycosaurus Lycosaurus is offline
Default L and R
Originally Posted by Don Jones View Post
The cap will only go on one way when the wires are placed in the holes where they belong. The L & R markings are next to the holes where you place the timing pin to set the mag up to be installed in either the left or right position. Put the pin in the left hole for the left mag and the R hole for the right.
Going from memory here ... but I believe R is for right hand rotation, and L is for left hand rotation.
Alfio
RV-9A Ottawa, Canada
First flight Dec. 18, 2008
> 1,000 hrs tach.
Old 12-07-2009, 08:38 AM
Ah yes, the cap does only go on one way. thanks!
Aerosport installed my mag on the engine, so I shouldn't have to worry about a timing pin should I?
What about the wires... which wires go to which plugs?
Phil
RV9A (SB)
Ottawa, Canada
Old 12-07-2009, 08:43 AM
jetjok's Avatar
jetjok jetjok is offline
Default Look at the Wires
Look at the caps on the end of the wires,(where it screws onto the spark plug. You will see a stamp that indicates the cylinder and orientation. i.e. T-2 = Cyl 2, top...B-3 = Cyl 3, bottom.
Mark Ohlau
RV-6 N506MM VAF #1410
2017 Donation Made
Old 12-07-2009, 08:47 AM
ah yes, you're right. But with my setup, the lightspeed coils are on the top and so all the top cylinders are fed from that. Can I plug the "T" wires from the mag into the bottom plugs of teh corresponding cylinders?
Phil
RV9A (SB)
Ottawa, Canada
Old 12-07-2009, 08:48 AM
Don Jones's Avatar
And you would be correct, that's what I get for typing before I was awake!
Don Jones
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
Old 12-07-2009, 08:57 AM
OceanBob OceanBob is offline
Default Left hand rotating slick
Number 1 should attach to cylinder 1. Going counter-clockwise is number 2 then number 3 and so on. I am assuming the mag has been internally timed (a pin that locates the shaft in the L hole to open E gap at 25 degrees BTC on cylinder number one) so all you have to do is attach the wires.
Old 12-07-2009, 09:07 AM
This does not correspond to the numbering on the plug ends of the wires coming out the back. Going counter-clockwise from 1, the order of my wires is 1,4,3,2.
What about the T vs B? Can I put all my mag wires to the bottoms of the cylinders (since the tops are all fed by the lightspeed coils)?
I've emailed Aerosport for confirmation...
Phil
RV9A (SB)
Ottawa, Canada
Old 12-07-2009, 09:15 AM
Radomir's Avatar
Radomir Radomir is offline
Just ignore "T" and "B" and go by numbers only... T1 will go to cylinder #1.. and will work fine either at top plug or bottom plug location.
Remember, (with two mags) both plugs fire at same time, so it doesn't matter whether it's top or bottom that the wire's connected to... it doesn't care..
Radomir
RV-7A sold
