Old 12-05-2009, 04:39 PM
Default Two Blades and It Was Running!
Temp dipped down to 19F around here last night and I really wondered if the trusty Lycoming would thunder to life.
Evidently, I have just about figured the right amount of prime with Don Rivera's AFP system, 4.5 seconds of prime with the throttle wide open, hit the starter and it came to life after 2 blades swung by....what a deal!
Four of us blasted off for a half hour flight for lunch. Not a bad way to live between storms in the Midwest during December.
Life could be worse....
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 12-06-2009, 07:03 AM
yakdriver yakdriver is offline
No pre-heat?
RV 7 N212MD Flying as of 12/22/2007
Backcountry/TCOW Super Cub flying 03/12/2011
Next project?
Old 12-06-2009, 07:16 AM
Originally Posted by yakdriver View Post
No pre-heat?
None.
While it got down to 19F, inside the hangar the concrete floor kept the place much above that temp. I did not check it, but would guess it was about 25-30. I turned the engine through by hand and it was easy - the oil is Phillips 20W50 with a bottle of AVBLEND to keep the top end lubed.
RV-12 Build Helper
RV-7A...Sold #70374
Old 12-06-2009, 08:32 AM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Cold
I think my 4.5 year old Odyssey 680 is starting to degrade. The other day after working all night, I got in my plane to come home. The OAT was 35 degrees. I had trouble getting it to turn over. Finally, after a decent prime it fired.
Couldn't deal with your type of cold, David. Stay warm!!!!
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 12-06-2009, 09:41 AM
agough277 agough277 is offline
In these cold temps it takes a little longer for fuel to turn to vapor. I prime my engine the first thing, attach seat belt and headset then start. Try waiting a while after priming before hitting the starter. I know you see I live near Las Vegas but the temps here get into the teens at night.
RV6A, RV7, RV6 Wing
Living with my 6A at 3L2 near Las Vegas
Old 12-06-2009, 10:32 AM
scard's Avatar
scard scard is offline
We are completely out of sorts with the recent actual cold temps. I think it was about 26F when Tanya went out to fire up yesterday morning. She said it took her four tries to get it lit.
Scott Card
CMW E-Lift
Old 12-06-2009, 05:58 PM
zilik's Avatar
zilik zilik is offline
VAF Moderator
Default Training needed!
Cold start training needed.
Gary "Seismo" Zilik
Pine Junction, Colorado
RV-6A N99PZ S/N 22993 SOLD
Old 12-06-2009, 06:26 PM
Geico266's Avatar
Geico266 Geico266 is offline
Originally Posted by David-aviator View Post
None.
It's a good idea to preheat below 40F if you have it. Starting is one thing, getting cold oil to flow into the journals is another. JMHO.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 12-06-2009, 06:53 PM
AlexPeterson's Avatar
You can hear the oil pump cavitating at idle (not the end of the world, but also not good for the pump's metal surfaces) when the oil is below about 50 degrees. The pump will jam the oil through the discharge end, but it only has one atmosphere to push the oil into the pump. The sound is vaguely similar to that of a power steering pump that is low on oil. A growl of sorts.
I strongly recommend either pre-heating appropriately or keeping the cowl all covered up and heated from within. Tons of thoughts on that in these forums.
Try pouring a quart of your favorite oil in the engine at 32F.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
