Old 12-05-2009, 06:59 AM
trib trib is offline
Question air/oil separator question
I'm looking for opinions on using an air/oil separator. I plan on general flying using the abilities of the plane for sport aero. Is a separator typically installed? If so, if you have installed one and think it gives good results, what kind is it? Looking for some recommendations here. I checked ACS and they have several. This one- http://www.aircraftspruce.com/catalo...ilbreather.php
is only $50 and looks to be of good quality. Has anyone used one of these or heard of any results?
I went for transition training this past week with Jan Bussell. I highly recommend it. He did an excellent job.
I also used the RV Hotel and called up Turbo Eddie for a place to stay. Not only was he a great host, he wouldn't let me drive the hour to Okeechobee to fly with Jan. He flew me over and back. Thanks again Eddie for a great couple of days. There sure are a lot of good people (RV'ers) in Florida.
Also, thanks DR for a great website. The RV experience wouldn't be the same without it.
Tim Ribble
Virginia Beach
RV-6A (only took 13 years to build )
N621TR In unrestricted operation
Old 12-05-2009, 07:11 AM
Mel's Avatar
Mel Mel is offline
I've tried several air/oil separators including the one you listed and removed them all. In my experience, I get about the same amount of oil on the belly with or without a separator.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 12-06-2009, 03:25 AM
ronschreck's Avatar
ronschreck ronschreck is offline
Default Look here:
http://www.vansairforce.com/communit...ad.php?t=51286
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2021 Donor
Old 12-06-2009, 10:59 AM
N427EF N427EF is offline
Default Oil Sep
Agree with Mel.
I have tried a couple, one of the cheap ones and one of the expensive ones.
While I never really had oil on the belly I had a drip or 2 coming out the breather tube after shut down.
Now I have no drip for the first 20 hours after an oil change and after that
I get progressively more drips until I change the oil.
My 10 will not have an oil separator, makes for less stuff on the firewall.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
Old 12-06-2009, 11:13 AM
Bavafa Bavafa is offline
I have installed the one from VANs (more expensive) and I get about zero oil in the belly. I exit route is on the exhaust and there is no stain on the exhaust for the oil burn, and I usually keep the full 8 qt of oil in the engine. So, I highly recommend it.
http://vansaircraft.com/cgi-bin/cata...roduct=air-oil
Mehrdad
RV7A - IO360M1B
Old 12-06-2009, 12:25 PM
Tom Martin Tom Martin is offline
I have owned and flown a number of RVs and rockets and it really depends on the particular engine and/or installation.I would reccomend flying without the separator and seeing if it is needed first. It is not hard to add one later. I have built one myself using two soup cans, one inside the other. It was a fun little project that actually worked! The price was right and it looked just funky enough to be interesing.
Tom Martin RV1 pilot 4.6hours!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
2010 SARL Rocket 100 race, average speed of 238.6 knots/274.6mph
RV4, RV7, RV10, two HRIIs and five F1 Rockets
RV14 Tail dragger
Fairlea Field
St.Thomas, Ontario Canada, CYQS
fairleafield@gmail.com
Old 12-06-2009, 12:32 PM
Greg Arehart's Avatar
I've had more oil on the belly than I like, so I recently fabricated one from some Al tubing, stuffed with stainless steel scrub pad - similar to the Bingelis design. Just installed, so few data on effectiveness, but in 4 hours it looks to be cutting down on any oil getting away.
greg
Greg Arehart
N 7965A
Old 01-15-2010, 05:58 PM
N941WR's Avatar
N941WR N941WR is offline
Mehrdad
RV7A - IO360M1B
Is anyone else running this separator? If so, what are your thoughts on its effectiveness?
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 07-12-2011, 09:57 AM
carbonglass carbonglass is offline
Default Advanced Aero Components, Air/Oil Sep
Advanced Aero Components ,www.advancedaero.com,
I just fitted an advanced aero components 310 Air/oil separator to my Rv7,
seems to be the first one that i had that works reasonably well.
Really nice workmanship and serviceable, apparently they specialise in extra Vans Rv gear
Ben
Old 07-12-2011, 01:27 PM
asav8tor asav8tor is offline
Out of the breather comes:
-oil mist mixed with, water, water vapor, acids and other products of the combustion process.
The separator returns not only oil to the engine but also much of the junk you would like to get rid of. Take your pick, (1) cleaner belly or (2) cleaner oil in your engine.
There are better solutions, breather exit slightly above the exhaust pipe or a long breather going all the way to the tail.
