Old 12-03-2009, 12:55 PM
PaulR PaulR is offline
Default Dimming SL-30/GTX-327
I'm in the middle of wiring and getting ready to do the IP. I hadn't thought about dimming the radio and xpndr until I really got into the schematics for them. Is it feasable to dim them off of the same dimmer that I'm using for the LED light strip on the bottom of the glare sheild? (Van's Dimmer) Or do I need to put those two items on a dimmer by themselves? The Dynons dim themselves, sort of, so they don't need one. The only other dimmer I have planned is for the map lights on the canopy deck.
Paul Rose
RV-9A 91300
N417PR
SERFI 2013 Awards
Inspection Complete!!! 7/7/12
First Flight 7/22/12
Old 12-03-2009, 01:06 PM
aparchment's Avatar
aparchment aparchment is offline
Default not what you asked
Hey Paul:
I know this isn't the answer you were looking for, but you may prefer to have your glare shield on a separate dimmer from the instruments. I know when I am flying at night I like to have the panel light at a different intensity than the instrument lights in various situations. The 2001 skyhawk I fly at night has separate dimmer controls for the primary instruments, panel, MFD and GPS, and I find it useful to alter the lighting during different stages of the flight.
Just thought you might want to give it some thought.
Antony
Antony
RV-7A
Empenage complete, wings complete, tip-up canopy complete, starting wiring ...
Old 12-03-2009, 01:10 PM
Don Jones's Avatar
Don Jones Don Jones is offline
Both the SL30 and the GTX 327 have sensors on the front of the units and the display automatically dims. Shouldn't need a dimmer unless you just want to use those inputs on the units. I have never seen the need to have manual control of the dimming. The automatic works fine for me.
Don Jones
Technical Support Manager
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
Old 12-03-2009, 01:15 PM
the_other_dougreeves the_other_dougreeves is offline
Huh. My SL40 auto dims (built in photocell?) and the G327 switches into a "night" mode with the LCD reversed. Never wanted to hook either one up to a dimmer, but I don't fly at night much.
The 327 install manual has info on how to set the minimum backlighting settings.
TODR
Doug "The Other Doug Reeves" Reeves
CTSW N621CT - SOLD but not forgotten
Home Bases LBX, BZN
Old 12-03-2009, 01:45 PM
Default Thanks
Thanks guys, I guess maybe I should work more while I'm at work than thinking about the airplane when I don't have the manuals in front of me. I thought I had read about the auto dimming on the Garmin stuff, but instead of waiting till I got home and reading, I just asked. Some day I'll learn.
Paul Rose
RV-9A 91300
N417PR
SERFI 2013 Awards
Old 12-04-2009, 08:45 AM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Won't need to
Hi Paul,
I fly a lot at night and you won't need to have a dimmer. They both dim nicely on their own. Now the 430 is another matter. This can be manually dimmed but it is a multi step process.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 12-04-2009, 01:51 PM
db8's Avatar
db8 db8 is offline
Default Suggestions for the 430?
I am starting the electrical also and have decided not to use a dimmer for the Garmin comm or nav (based on this post). So do you think that dimmer should be used for the 430, or just do the multistep process to dim the 430? Haven't done the research to find out if a dimmer can even be used on the 430 if desired? Thanks. Dave
Dave Buntin
http://i55.tinypic.com/iny6qa.jpg RV-8, N 130YS, BOYS & TOYS
[size="1"][color="Blue"]
Old 12-28-2009, 09:56 PM
foka4 foka4 is offline
Default 327 and SL40
I've flown quite a bit at night with a GTX 327 and an SL40 in a certified aircraft, and have found the auto dimming to be entirely satisfactory. I think the SL40 has some adjustment in the setup menus to tailor the behovior of the auto dimmer, but I don't recall ever having to mess with it.
I know there are many aircraft in the fleet that have a 327, SL40, and 430 all mounted together in a stack, and I'd love to hear practical accounts of how the systems were set up with respect to dimming, and how they perform in night IFR flying.
M
