Old 12-03-2009, 11:57 AM
AcezHi's Avatar
AcezHi AcezHi is offline
Default Electric vs Manual trim
I am ready to order my Emp kit and want to get some opinions on Electric vs Manual trim.
What are your thoughts?
EAA Chapter 87
8 Emp Completed.
Building Wings.
https://picasaweb.google.com/acezhi/...eat=directlink
Old 12-03-2009, 12:11 PM
Sid Lambert Sid Lambert is offline
Manual - Easier to fine tune in flight
Manual - More reliable
Electric - Weighs less
Electric - Can be integrated with a fancy autopilot
It's just up to you. Most people seem to build electric systems now-a-days. I don't think anyone who is familiar with RV's would be reluctant to buy an airplane with manual trim though. So little to no resale impact.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
Old 12-03-2009, 12:25 PM
MCA's Avatar
MCA MCA is offline
I prefer the electric trim, and with variable speed trim functionality (like in Vertical Power) it is very easy to fine tune in cruise.
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
Old 12-03-2009, 12:33 PM
N941WR's Avatar
N941WR N941WR is offline
Click on the search button. Lots of info on this topic already out there.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 12-03-2009, 01:58 PM
AcezHi's Avatar
Talking Just hoping for the newest possible information
I did search around and read a ton of posts, just wanted to be as current as possible.
It is a decision that I need to make soon and I like to research as much as I can.
EAA Chapter 87
8 Emp Completed.
Building Wings.
Old 12-03-2009, 02:06 PM
N941WR's Avatar
Actually, you can change it later. Even after the plane is flying.
I suspect there was nothing new to read on this topic. The big thing is if you go electric, where would you like your switches? Lots of people put them on the stick grip but that requires the added complexity of solenoids.
Too many production planes that I have flown had inop electric trim. They all had manual backup systems, which the RV does not. Keep in mind, you can easily over power the RV's trim, even at full deflection. It is just a pain to do so.
What I'm sure you read was that both trim systems worked and worked well. It is all up to you to pick the one you want. Either way, you can't go wrong.
Bill R.
SC86 - Easley, SC
Old 12-03-2009, 03:48 PM
Rick_A's Avatar
Rick_A Rick_A is offline
... The big thing is if you go electric, where would you like your switches? Lots of people put them on the stick grip but that requires the added complexity of solenoids.
Bill, what makes you say that a solenoid is needed for a stick grip switch? I don't have a solenoid for my basic hat switch on my stick grip.
I did wire in a speed controller for the electric trim (Matronics) but I don't know if that is really even needed.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 12-03-2009, 03:55 PM
Dmadd Dmadd is offline
Manual. That trim motor never breaks. ;-)
Old 12-03-2009, 04:06 PM
kentb's Avatar
kentb kentb is offline
Default solenoid are not needed.
If you only wire in one stick, no solenoid is needed.
If you wire in two controls then you need the solenoid.
Electrons are light weight and easy to install.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
Old 12-03-2009, 05:55 PM
rvbuilder2002's Avatar
Kent
What is actually required is a relay. I believe a solenoid is considered to be an electrical device that produces a mechanical action.
A relay is need for some of the commonly used stick grip switches because they are not rated for the current draw of the trim motor. If a speed control is used it negates the need for a separate relay.
If we are voting for a favorite... after flying many hours in many different RV's I prefer manual elevator and aileron trim. Very precise and I can very quickly get the exact amount of trim I want, exactly when i want it.
I think Bills point was that you don't have to choose right now...If you go with manual right now (makes the emp. kit cheaper) you can easily add the electric later when nearing teh end of your build if you change your mind.
Scott McDaniels
Hubbard, Oregon
