Generally speaking, rivets are like bolts. The head goes up or forward. But that's just a guideline, and not nearly as important as with bolts. A more important consideration can be the thickness of material; the head should go next to the thinner material and the bucking bar next to the thicker material. There can be other considerations, too. If there are clearance issues, it's often easier to plan around the manufactured head (I'm thinking of the aft deck on my -6A, where the horizontal stab has a spacer to clear the deck rivets; driven the other way, if that were possible, an underdriven rivet might interfere). And that brings us to what is probably the most important consideration: which orientation can you drive the rivet in. In the above example, it is simply not practical to have someone crawl into the tail and drive rivets in that tight space while you buck outside. In the area you are working, it doesn't make a lot of difference either way so you can fall back on the final consideration: what looks better to you? Generally, if an unusual orientation is critical, the plans will note it.
EAA Technical Counselor #5357
