03-09-2010, 08:38 AM
Ron, on your Accusump, did you install the electric switch activated valve so you can close it off before engine shut down and store the oil for pre-oiling on the next start up?
Dave "WS" Rogers
RV-8 N173DR
03-09-2010, 03:41 PM
No. I fly enough that I don't worry about having a dry cam or bearings at start-up.
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2021 Donor
03-09-2010, 03:56 PM
Pictures of Raven/Accusump Installation
Ron,
Any pictures or details on how the accumulator is plumbed into the engine?
I have the Raven system minus the check valve installed. I have not decided if I should ditch the check valve in favor of the accumulator or try running them together. I believe you stated at one time that Danny King was running both.
Danny --- any comments?
David
03-09-2010, 04:12 PM
Originally Posted by DeltaTango
Ron,
David
I plumbed into a "T" fitting at the top of my oil cooler. See the third picture in post number 6 of this thread.
Ron Schreck
IAC National Judge
VAF 2021 Donor
03-21-2010, 10:16 PM
Thanks Smokey
For this thread.
I added the half-Raven during the annual inspection. The folks at Raven sent everything I needed except some #6000 hose. I haven't added the accumulator yet, but still feeling good just knowing my tail will not be dripping oil all year.
Don
Don Hall
N517DG - RV7 - Flying!
Ticked Van's Hobbes meter at #6110, 3/7/09
03-22-2010, 03:08 AM
Originally Posted by dhall_polo
For this thread.
Don
Now if we can just find a way to keep the smoke oil off the belly...
Happy Hammerheading,
Ron Schreck
IAC National Judge
VAF 2021 Donor
03-22-2010, 09:01 AM
Thanks Smokey!
Mutha was wondering what his next mod would be.
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
09-07-2015, 12:59 PM
I am thinking of installing the same in my RV-8 ( I am also only looking for short periods of inverted flight and I am just tired of cleaning my hanger floor after every flight ... ) so I figured I ask if you are still happy with it after using it for a couple of years.
Thx
Oliver
09-07-2015, 07:07 PM
Thx
Oliver
Oliver,
I have since upgraded to a full inverted system for sustained inverted flight but for your purposes the half Raven will work great. Go for it.
Ron Schreck
IAC National Judge
VAF 2021 Donor
01-07-2016, 08:14 PM
My Half Raven
Thanks to the excellent advice I got here, I chose and just finished installing a Raven Inverted Oil System - just the air/oil separator system. This is commonly referred to as the Half Raven since I didn't install the pressure side inverted oil valve components. My objective was to eliminate the excessive loss of oil and messy airplane I was seeing after my aerobatic flights. I have a carbureted 360 so sustained inverted isn't a requirement. I just wanted to eliminate the mess and the oil loss.
I can happily report great success. I flew the first flight today and, after putting the -4 through some very extensive zero and negative g maneuvers, I returned to find very little oil on the belly and no measureable oil loss. Before the installation of this system, I was seeing a quart to a half-quart loss on some of my more aggressive flying days and the belly would be a complete mess.
This experience also highlighted to me the value of the experimental aviation world. I learned a lot. I had to learn about and select all the right mounts, hoses and fittings, sealants, and tools. I built my first ever hoses. I think it took me three different shipments from Spruce and two from Summit Racing, but once I had all the right stuff, it was pretty simple. I enjoyed it immensely and the results provided a lot of personal satisfaction. I want to give a big thank you to the folks the produced the EAA videos on hose fabrication. They helped me immensely!
Also, a big thumbs up for the Raven products. Quality stuff that just works!
Randy
Randy King
Tampa (Wimauma), Florida
RV-4 N212CS (sold)
RV-8 N184RK (flying)
Flying an A320 to pay the bills
Exempt and gladly donating anyway - Current through March 2021
Reason: grammar
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
