Old 12-01-2009, 05:49 PM
g zero g zero is offline
Default angle valve rocker lesson
When installing your overhauled cylinders install the rocker shafts BEFORE you install the cylinders. You have room to move the shafts after the cylinder base nuts are on to install the rocker arms. I just went thru this on my HIO 360 c1a
Old 12-01-2009, 10:56 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
Not only that, but if you're just changing cylinders without splitting the case, remember to pull out the hydraulic lash adjusters and purge out the oil...
Don't ask me how I know.
Old 12-03-2009, 12:54 PM
I did that right this time ( learn that lesson on an o200 that I had to remove the cylinders to get the lifters out)
