Oops Rivets
Robert,
"Oops" rivets are NAS 1097. They have a shank one size larger than "normal" with a normal size head.
Avery sells a kit with an assortment or you can buy them in bulk from Vans or Aircraft Spruce.
Stop by the house and I'll fix you up with an assortment to get you started.
Standard rivets also come in a variety of shank diameters...you can probably just go up one diameter. Check the General Aviation Hardware catalog for size references.
Good luck,
Mike
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
