switch help
I used the Z11 wiring diagram for my RV7a electrical. I have two 2-5 toggle switches for the left mag/start and right mag. I now want to put a key switch in the starter circuit that will break the continuity if the starter/toggle switch is accidentally hit. Any suggestions on the type of keyed switch I might use.
