Old 11-30-2009, 06:03 AM
jonweisw jonweisw is offline
Default Boroscopes and Cylinder Heads
All - I am in the midst of an annual on my 460h IO-360M1B on my RV-8, and, having never done this before, I decided to boroscope the cylinders. I was surprised to find that the cylinder heads had large patches of multicolored irregularities - some cylinders worse than others - almost like flat patches of material. I dont think that it represents rust as I fly pretty regularly, but I was surprised by the amount of it (unfortunately I couldnt get a picture with this particular scope). The cylinder walls looked good as did the rings.
Does anyone know what this is? I run my engine with aggressive leaning to keep it about 50deg rich of the hottest cylinder and the cht's all run within about 10-20deg of each other. Compressions are all very good (76-80).
Anybody with some grey hair on this subject have any thoughts?
Jon Weiswasser
N898JW
Old 11-30-2009, 06:24 AM
RV6_flyer's Avatar
Originally Posted by jonweisw View Post
--- SNIP ---
Jon Weiswasser
N898JW
Normal carbon / combustion by-product build up.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 11-30-2009, 07:48 AM
Daver Daver is offline
Default bore scope
I bore scoped my cylinders on my used (450 hr SMOH) o-320E2A engine.
I also spotted some discolored patches.
I later removed one cylinder to inspect camshaft lobes. It all looks OK as far as
I can tell.
I wouldn't worry about it.
Dave
-9A finish kit
N514R reserved
