Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 11-29-2009, 06:00 PM
cjensen's Avatar
cjensen cjensen is offline
Default Weird problem with G295 wired in to the panel
I put the fuses in my blocks yesterday, one by one, and when I got to the 295, it powered up, but pretty close to immediately, it went in to this "Lost external power" loop. About a second after the window pops up telling me that message, it goes away for about a second, then pops open the window again. It will do this over and over again until I either unplug it, remove the fuse, or power it down with the power button.
Anyone have any suggestions on where to start with this one?
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 11-29-2009, 06:18 PM
Mel's Avatar
Mel Mel is offline
This may or may not be help, but I let my 495 battery go completely flat and it gave me similar side effects. Once I plugged it in to AC charger and charged up the battery, it went back to normal operation.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-30-2009, 08:41 PM
cjensen's Avatar
Update...I found the problem! It just so happens that the first time I turned on the 295 while plugged in to ship's power, the PC680 had dropped to 9V's (multiple LED light show-off's and Enigma setup prior to me doing this drained the battery a bit) and the 295 couldn't figure out whether to switch to battery power or stay with ship's power. I pulled the battery today to put it on a trickle charge all day, and the 295 now powers up just fine with ship's power.
So I guess I know where the 295 will start to switch now!
Chad Jensen
