antenna check
I like to check things with my multimeter... if only to teach myself things.
When I use the multimeter between the center conductor of the female BNC connector on my xpndr antenna and the tip of the antenna itself, I get (nearly) zero resistance. But when I do the same check on my COMM antenna, I get not conductivity between the center conductor and the tip of the antenna. Is this normal?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
