Old 11-26-2009, 08:15 AM
prkaye prkaye is offline
Default electrical post - brown insulating washer?
My mag post has this brown plastic/composite washer. Should my terminal go on top of this washer? Why is it there? why would you want to INSULATE the terminal from the base of the post?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 11-26-2009, 08:25 AM
Mel's Avatar
Mel Mel is offline
This composite washer is what isolates the "P" lead from ground. Without it, your "P" lead would be grounded, placing the mag in the off position continuously.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-26-2009, 08:28 AM
So that threaded post is not electrically connected to that big metal hex-shaped surface below it?
Phil
RV9A (SB)
Ottawa, Canada
Old 11-26-2009, 08:30 AM
Mel's Avatar
Mel Mel is offline
That's correct!
Old 11-26-2009, 08:33 AM
Thanks Mel!
As always, the community on this forum really helps make amateur-building the educational endeavour that it should be!
Phil
RV9A (SB)
Ottawa, Canada
Old 11-26-2009, 09:36 AM
Brantel's Avatar
Brantel Brantel is offline
Yep that stud that sticks out of the center is actually insulated from the big hex part by a glass insulator.
If you over torque the P-lead nut, you can crack that glass insulator.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
