11-26-2009, 07:14 AM
Short pilots/passengers and rudder pedals
What has been done for vertically challenged passengers or pilots? I?m talking around 4?10?. Is there some way to adjust the rudder peddles per side? Strapping blocks to the peddles? But then how do you use the toe breaks?
This is for a -6A with the over head mount type.
Thanks!!
Michael Delpier
RV6A -O-320, fixed pitch, GRT Sport, 496
RV-10 - working on finish kit
Houston
11-26-2009, 07:19 AM
The rudder pedal "blocks" can be moved aft on the longerons. You will have to make a new center brace and also have to shorten the rudder cables. I've done this on a couple of RV-6s.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
11-26-2009, 09:15 AM
Thanks Mel.
I am looking more for an adjustable idea. I am still "normal" sized, but the wife is a little on the short side
Ideal would for one side for a 5'11" and the other to be for a 4'10" person.
Michael Delpier
Houston
11-26-2009, 09:23 AM
Originally Posted by Mike D
Thanks Mel.
How about 4-6" seat cushion? We have one short gal in our club and she has to use quite a thick pillow behind her back in C172 to get to the rudders and it works great for her.
11-26-2009, 10:12 AM
I hereby trademark the unique ExtendoRudder. Quickly bolts to your current RV rudders and allows short people to operate the rudders normally.
11-26-2009, 11:07 AM
A cushion that thick might impinge on getting full stick deflection.
Better to adjust the rudder pedals in some way.
Mark Ohlau
RV-6 N506MM VAF #1410
2017 Donation Made
11-26-2009, 11:10 AM
While a good idea on C172 and others, the RVs have a stick. There is only so much pilot/copilot forward positioning that can be done, then the stick gets real uncomfortable, especially on climb :-)
Alfio
RV-9A Ottawa, Canada
First flight Dec. 18, 2008
> 1,000 hrs tach.
11-26-2009, 12:20 PM
Here's a thought...
Mike,
If she is always going to fly on one side, extend the center brace. Then add a 3rd set of rudder pedals to the right side only. These would be aft of the current pedals.
Tie the auxiliary set of pedals to the original set with a short rod and rod end bearings.
You could also add brake pedals the same way.
You could make the tie rods so they are easily removed and a latch so the aux pedals can be flipped up out of the way and secured.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
11-26-2009, 08:45 PM
Thanks Bill!!
I like the idea.
Michael Delpier
Houston
11-26-2009, 11:11 PM
rudder pedal extentions
I've used these and am very happy with them:
http://www.mlblueskunk.com/Rudder_pedal_Extensions.html
They made them a custom (longer extention) size for me and added an extention for the top of the brake pedal to get the foot angle right for me.
Jeremy Constant
