Old 11-25-2009, 09:27 AM
pvalovich pvalovich is offline
Default -8A QB Fuselage Question
The answer's probably in the plans somewhere, but I haven't been able to find it.
The -8A QB fuselage has a hinge pin running laterally near the front of the bottom fuselage, holding a panel against the fuselage bottom. What is the purpose - and when does one remove it?
Thanks in advance for aiding my laziness.
Old 11-25-2009, 10:46 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
IIRC, this was part of a planned cowl flap arrangement, that never got into production.
Seems to me that Dan Horton, Dan H in the forum, posted info about this.
Been a while back, try searching for it and reset the search time line to any time, default is 1 year ago.
Did a quick bit of searching, found this http://www.vansairforce.com/communit...0&postcount=14
Good luck.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 11-25-2009, 06:45 PM
chaskuss chaskuss is offline
Good luck.
Mike,
Actually, I found a post 2 months prior to the one you link to, where I mentioned this. It's the last post on the thread below. See
http://www.vansairforce.com/communit...t=cooling+ramp
Dan might have mentioned it earlier, I don't know. He sure has a lot of great ideas!
Charlie Kuss
