Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 11-24-2009, 02:11 AM
Doug Rodrigues Doug Rodrigues is offline
Default Pros or Cons: Full feathering Hartzell hc92zk-2B 8447-12a
Does anyone have any comments about mounting a full feathering Hartzell prop from a Twin Beech Travel Air to a O-360A1D on an RV-8? The Travel Air cruise speed is about the same as an RV-8....I think? Don't know about the prop governer though?
Old 11-24-2009, 11:54 PM
Dragonfly Dragonfly is offline
Is there a particular reason your thinking of full feathering? have you got a deal on it?
Old 11-25-2009, 03:47 AM
Kevin Horton's Avatar
Having a full feathering prop would buy you a small amount of glide performance improvement, but adds a new failure mode. If the prop governor fails, the prop will feather. Personally, I would prefer to not have a feathering prop, unless I had a multi-engine aircraft.
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
Old 11-25-2009, 05:08 PM
Default It's a good deal.....but....
I've been talked out of it. Too many unknowns and maybes, plus no aid in slowing down with the power pulled way back. It was just a consideration of getting a prop cheap and into the air faster.
Old 11-25-2009, 05:56 PM
n5lp's Avatar
n5lp n5lp is offline
fugio ergo sum
I've been talked out of it. Too many unknowns and maybes, plus no aid in slowing down with the power pulled way back...
It would still have the braking effect of any other CS prop.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
Old 11-25-2009, 07:27 PM
... plus no aid in slowing down with the power pulled way back.
As long as the engine is developing oil pressure, and the prop governor, oil line to prop, etc are serviceable, it will work like any other constant speed prop. I.e. the prop governor will control the blade pitch to attempt to keep the rpm at the selected value. So, if you pull the power back, the rpm will fall, and the prop will go to fine pitch. Exactly the same as any other constant speed prop.
Kevin Horton
RV-8
Moses Lake, WA, USA
Old 12-01-2009, 09:19 PM
Default Just got information from a Hartzell engineer....
**He said that the feathering prop is 20 lbs heavier that the Hartzell compact hub with the 7666 blades. Didn't know that.
Old 12-01-2009, 10:16 PM
TCONROY's Avatar
TCONROY TCONROY is offline
You'll get a surprise when you accidently run out of gas on the right side and it feathers before you can switch. Just hypotheticals but I really don't think its a good idea to have a fully-feathering prop on a single-engine piston.
________
Trevor Conroy CFII, MEI
Airbus Pilot
N781TD
RV-7
First Flight - April 12, 2015
Construction Log
Old 12-02-2009, 12:24 AM
John Clark's Avatar
John Clark John Clark is offline
Default Won't feather by itself
Doesn't work that way, you would have to pull prop control all the way back to feather even if the engine is just windmilling. Otherwise, the prop would feather every time you shut the engine down.
John Clark ATP, CFI
RV8 N18U "Sunshine"
KSBA
