The intent for the wing "scarf joint"...
...was to have the wing skin joint (in the area immediately behind the fuel tank) match up flush, height wise, with the wing skins. This was only for the immediate area behind the tank. The two layers of wing skin, where they overlap each other, caused the top skin to sit proud of the tank skin. This could be taken as a "cosmetic issue" by some builders, so the area immediately behind the tank skin, in the area of the overlapped top skin, could be optionally "scarfed". If utilized, the scarf should only be for about a 1" x1" area, scarfing the bottom skin and then matching the mirrored operation with the top skin. If not scarfed, the top skin sticking proud obviously catches / disrupts some air flow in this area.
For the fuselage skin, the forward skins lay on top of the after skins in a more streamlined manner, so airflow is minimally disturbed.
