Old 11-22-2009, 11:15 PM
Michael Burbidge Michael Burbidge is offline
Default Fuel tank leak test
Tonight I was doing my fuel tank leak test on my second tank using the Van's test kit. I used the plug to plug the fuel pickup fitting, I put a balloon on the vent line fitting and I put the valve stem on the drain valve fitting. I then started to pump up the tank.
The results were disappointing. The balloon was not even moving. I could hear air going into the tank. But with the balloon not even moving I figured there must be a huge leak. I was also worried that maybe the vent line was plugged. If that was the case I needed to be careful not to explode the tank. I spent 15 minutes trying to figure out if the vent line was plugged or if there was a huge hole somewhere. It seemed like I should be able to hear the air coming out of such a big hole.
I was just about ready to get out the soapy water, when I realized that I had not put on the fuel cap...
After slapping myself in the forehead I had a good laugh.
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
Old 11-23-2009, 07:02 AM
jmbrwn's Avatar
jmbrwn jmbrwn is offline
Now that's funny!!! Hey, we've all been there. But you were really relieved when you realized that was the only problem.
Jim Brown
RV6, Christen Eagle II(Sold)
ATP, CFII, A-IGI, A&P/IA
Carrollton, GA
Lyon?s Landing
Old 11-23-2009, 08:47 AM
Sounds like something I would do....haha
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
