Old 11-22-2009, 11:10 PM
Default Van's Transponder antenna vs. B&C
B&C sells a little rod-type transponder antenna for $17. Van's sells a rod transponder antenna for $95. what does that additional $78 buy me with the Van's version?
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 11-23-2009, 07:02 AM
the_other_dougreeves the_other_dougreeves is offline
$95, yikes. You can almost get a low-drag fin type for that (e.g., RAMI AV-74). Even commercial rod-style antennas should be $50 (e.g., RAMI AV-22).
TODR
Doug "The Other Doug Reeves" Reeves
CTSW N621CT - SOLD but not forgotten
Home Bases LBX, BZN
Old 11-23-2009, 07:20 AM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default cheap one
Get the cheap one. They work fine.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 11-23-2009, 07:25 AM
Good. I already have it. Just got a little concerned when I stumbled across the much-more-expensive Van's version.
Now, who's got a recommendation for a belly mounted comm antenna.
Oh, and I built my first harness that will require it.
Bob Collins
St. Paul, MN.
Old 11-23-2009, 08:46 AM
az_gila's Avatar
az_gila az_gila is offline
Thumbs up And they are cheap enough...
...to buy a spare. They do seem to break off when folks work under your plane and roll/slide around....
I've seen 5 broken transponder antenna locally in the last few years.
You will be liked by your buddies when you have a instant replacement for their broken antennae....
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-23-2009, 09:01 AM
tc1234c's Avatar
tc1234c tc1234c is offline
I broke two, both times when I was washing the belly with a brush. I figure it must be designed so it does not poke a hole in someone's head. When my first one broke I went to an avionics shop and paid $90 for a replacement (I needed it for a trip to class C airspace). Then, I brought three from ebay for $12.45 each (mfg by TED). I saved the stubs and later crimped stainless steel hinge pins and made my own belly bend antennas for APRS tracker and a 2nd com. They both work out fine. ATC never had problem with me, however, my ZAON MRX PCAS frequently lock in my own transponder return. It might be a problem from the antenna (just my speculation).
Ted Chang, VAF #681
2018 Due paid
Old 11-23-2009, 10:42 AM
Rick_A's Avatar
Rick_A Rick_A is offline
I got a Comant CI-101 stick antenna that I'll sell for $50. It's got about 100 flight hours on it.
I replaced it with a CI-105. I like the look of the CI-105 better and it seems a bit more substantial.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
