Old 11-19-2009, 01:45 PM
apkp777's Avatar
apkp777 apkp777 is offline
Default Nav antenna belly mounted?
Has anyone mounted their NAV antenna on the belly and if so, any pointers for my installation? Any problems with VOR/LOC/GS reception?
Tony Phillips
N524AP, RV 9 (tail wheel)
Old 11-19-2009, 01:58 PM
rv9av8tr's Avatar
rv9av8tr rv9av8tr is offline
Default Nav antenna
Nav (as in VOR/ILS) is a horizontal polarity signal, which means the antenna leads need to be parallel with Earth. Not exactly suitable for belly mounting since the leads would stick out beyond the sides of the fuse. The only "safe" spot would be under the fuse with the wings. Swirling high velocity prop wash might make them vibrate a lot.......
I'm thinking there is a history/reason they've always been mounted at the top of vert stabs.
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
Old 11-19-2009, 02:02 PM
Brantel's Avatar
Brantel Brantel is offline
Lots of people mount them under the tail cone in the back. They look and work fine there.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 11-19-2009, 02:04 PM
apkp777's Avatar
Yes, by "belly", I meant empennage.
Tony Phillips
Old 11-19-2009, 02:21 PM
Garage Guy's Avatar
Garage Guy Garage Guy is offline
This thread has some discussion and pictures: http://www.vansairforce.com/communit...ad.php?t=46855
--Paul
Old 11-19-2009, 02:47 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Works just fine under the horizontal stab (that's where it is on Louise's RV-6), and I don't think I'd want a top-mounted one on an RV taildragger - too many people with eyes at JUST the wrong height....
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-19-2009, 03:17 PM
apkp777's Avatar
Yeah, I like my eyes and being 6'2 puts the tips right at eye level. As always, all your input is much appreciated.
Tony Phillips
Old 11-19-2009, 03:34 PM
N941WR's Avatar
N941WR N941WR is offline
Tony,
I have read that putting the nav antennas in the wing tips works well but have no experience with them as I only have a lowly 496 in my RV.
You might want to do a search on that. I have heard the com antennas do not work well in that location. Again, do a search to verify.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 11-19-2009, 03:43 PM
apkp777's Avatar
Bill,
I looked at the Archer wing tip option. Seems there are mixed reviews. I plan on using my SL30 for IFR enroute and approach, so I need to have solid reception. At this point I think back by the tail wheel bottom side is going to do the trick. I will have to fab a wedge mount adapter to get a good horizontal mount. Glad to hear yours is getting back together. Us -9 guys have to stick together. The nosewheel cult is ever growing!
Tony Phillips
Old 11-19-2009, 05:56 PM
N941WR's Avatar
Tony,
I was thinking more about putting a regular com antenna on the bottom and going with just the nav antenna in the wing tip. Just remember, and I don't think I need to remind you, this is your plane and you are the one who is going to put their butt in it. Do the research and do what you feel comfortable with.
I too have seen the whiskers mounted under the HS, safe and tucked out of the way.
If you are installing a metal prop, there shouldn?t be a problem with the extra weight back there.
Bill R.
SC86 - Easley, SC
