Originally Posted by charger81
I see FP/CS constantly debated but it is usually more about defending the choice made.
IMO, many go with the fixed pitch prop because of the initial expense of the constant speed.
I went with the C/S right up front because I knew of all the advantages before hand. I had switched from F/P rentals to C/S rentals a long time ago. There is no way that I would have been content with a fixed pitch RV, and purchasing the Hartzell was probably the number one priority above all else.
Better takeoff performance. Much more choices for landing. Quieter in flight.
Excuses such as C/S maintenance are only that. We re-grease during the condition inspection, and that's about it.
If you just transition from a Cessna 172 or Piper Warrier, to the RV, then you probably wouldn't realize the vast difference between the two props. But if you had flown something more complex, then the difference is quickly obvious...
My choice was made from prior & positive "experience". And BTW, I know of no RV owner around here.............who wouldn't prefer a C/S over their F/P. Just stating the facts.
L.Adamson ---- RV6A Hartzell C/S
