11-17-2009, 09:15 AM
inline fuses?
For the Dynon ammeter shunt, they recommend putting 1 amp fuses on both connections to the D-180. One option they give is to use 1 to 2 inches of 26AWG wire. I think it would be better to use proper fuses though.
I don't want to install another fuse block just for these two fuses... any recommendations for a type of fuse that i can easily splice in-line with each wire?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
11-17-2009, 09:26 AM
Inline fuses
B&C sells them. They come with a heavy wire (in a continuous circle) and fuse receptacle. Used these for seat heat and rear seat vest power supply. Secondary use of power outlet for charging batt.
Bill Dicus
Shorewood (Milwaukee) Wisconsin
RV-8 N9669D Flying 12/4/14!
Flying Pitts S-2A, Piper Lance
11-17-2009, 09:31 AM
Rob Kochman
RV-10, Flying as of March 2011 ( blog)
Paine Field (KPAE)
EAA Chapter 1440
11-17-2009, 09:51 AM
Fusible link is what I used right next to the shunt....
11-17-2009, 01:09 PM
Originally Posted by Brantel
Fusable link is what I used right next to the shunt....
That's what we did ... Made for a nice clean installation...
Dave & Trina
RV-9A Flying  - 330 Hrs. Painted  Finishing the interior.
11-18-2009, 08:48 AM
Is there any reason why I shouldn't use the cylindrical glass fuses for this? I found some inline fuse holders for these at NAPA, and they are nice and small. I would put them inline back behind the firewall, to avoid excessive vibration and heat.
Phil
RV9A (SB)
Ottawa, Canada
11-18-2009, 08:56 AM
I like fusible links for this application because no part of the current path is left unprotected. With inline fuses, you have some length of wire between the shunt and the fuse that has no short-circuit protection.
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
11-18-2009, 09:00 AM
But the current along a wire (and through the fuse, wherever it is) would be the same at any given time, being a path of negligable resistance. So, wherever you put the fuse, if the current in the wire gets too high, the fuse will blow before the wire will burn. Am I missing somethign?
To reiterate my question about the glass fuses... is there any reason why these are a no-no in aircraft?
Phil
RV9A (SB)
Ottawa, Canada
11-18-2009, 09:06 AM
Think about what happens if the wire between the shunt and the fuse chafes on something and shorts to ground.
mcb
Matt Burch
RV-7 (last 90%)
VAF #836
