Old 11-17-2009, 07:02 AM
Juan Pablo Juan Pablo is offline
Smile Fuel pressure for YIO-360 M1B
Hi guys, from Argentina. We are finishing an RV-8 here, with a new Lycoming YIO-360 M1B. Do you know which fuel pressure values are normal for this engine? Range from maximum to minimal values? I have the mechanical driven pump in the engine and an aux boost high pressure pump.
Old 11-17-2009, 08:16 AM
chaskuss chaskuss is offline
Juan,
Nominal fuel pressure is 25 psi for fuel injected Lycomings. For the acceptable range, I believe you can find your answer here.
http://www.vansairforce.com/communit...40&postcount=4
Charlie Kuss
Old 11-17-2009, 02:16 PM
Bavafa Bavafa is offline
I was told that it can run OK with as little as 9 PSI but I have set my limits to 15 minimum and with the mechanical pump it runs right at 25 PSI all the time.
