Wing/aileron/flap build Vertical/Horizontal?
I recently trial fitted my wings on my RV-6 QB to get position marks for tubing, etc. (I DO NOT intend to fit and drill the rear spar now)
Question: Is there any reason I can't install the ailerons/flaps while the wings are installed on a leveled fuselage. I have seen many builder websites showing a vertical aileron/flap installation using the wing jig but only one with a "horizontal" install (on the fuse). My wings are obviously QB and mostly finished and don't need to be kept in alignment.
I plan on using the template (mostly just to hold the ailerons/flaps) while I align the brackets using the wing/aileron tooling holes and a laser prior to drilling. I will also use some sort of metal strips to help insure that the airfoil shape is maintained.
According to everything I have read about the airfoil template, it is mostly useless (didn't have one drawn on my wing crate either) except to hold the surfaces up.
Don't ask me why but I am just getting around to installing my ailerons and flaps on the wings but I am.
Venice, Fl
